Best way to hit 400hp..... L98.........
Old Sep 12, 2001 | 04:36 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I want to start making plans to make the 'bird a little meaner.....
Right now, it pulls pretty good. Has a flowmaster exhaust system, and a K&N... thats it.
So whats next? I want to run low 12's.
Who has done it, and how?
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Sep 12, 2001 | 05:28 PM
ImportsRsloths's Avatar
AFR (or whatever good TPI 350 head you can get for a good deal) 190cc heads and a superram might get you kinda close to high 12's low 13's.
Old Sep 12, 2001 | 06:06 PM
robert1's Avatar
Get the October Chevy Hi-Perf. It tells the exact way on how to get there. It is a lot easier than we all think; low 12's at 111mph????????
Old Sep 14, 2001 | 01:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The October CHP has lots of errors in it. For one, they used AFR 190 heads, not L98 heads.
For an intake you want a Miniram for non-smog areas, and a SuperRam if you have to pass smog.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 14, 2001 | 03:04 AM
STOCKROC's Avatar
Afr 195's, miniram, zz409 cam, 52mm t.b, hooker super comps, at least 3inch exaust, custom chip, 4.10's and a t-5.
This is the combo i used on a stock L98 bottom end to run a 12.1@118 on bald nittos.
1989 Irocz
350 T-5
Old Sep 14, 2001 | 07:10 PM
DON 88T/A's Avatar
STOCKROC,what do you know about the zz409 cam?
I'm putting it in my mini-ram 383.
[This message has been edited by DON 88T/A (edited September 14, 2001).]
Old Sep 14, 2001 | 07:56 PM
Iroc n roll's Avatar
IMHO the best way to get cheap power is to add nitrous. Is your car a daily driver? I don't think there is a better way to get a solid dual purpose car than the bottle. You have hp when you want it....unless your a nut and want it all the damn time. Plus its relatively inesxpensive. Just my thoughts
Old Sep 14, 2001 | 09:47 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I guess I am a nut I always have to get on it. I have the bottle and I don't know if I like it that much yet. still waying pros vs cons but, the fun factor is there of course.
Old Sep 15, 2001 | 04:35 AM
STOCKROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by DON 88T/A:
</font>
Its a great topend cam. My powerband didnt even start untill after 3500 rpm and pulled harder and harder the further up the rpms went. Of course this was on a 350 not 383 so you should have some more bottemend.
FYI: Get good springs and a hydr rev kit. I had the stock afr springs on my heads, and I floated the valves somewhere around 7000rpms. Resulsting in catastrophic engine failure.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
