stock baseplate
Old Sep 14, 2001 | 09:49 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
stock baseplate
I was owndering can it be ported to flow good enough numbers for a powerful 350? As good as a superram base? I heard that the stock could actually be ported more than the superram. Is this true?
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
completely done over suspension, black paint with flames,
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Sep 14, 2001 | 10:26 AM
JucinGTA's Avatar
Heres what I did.
www.geocities.com/softtailduece01
Old Sep 14, 2001 | 03:33 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
IS porting easy to do? I have never done it before.
future mods:
Wifes new car:
future mods:
Old Sep 14, 2001 | 04:51 PM
formul8!!'s Avatar
Car: 2004 GTO
Don't waste your time with the stock manifold. Even a fully ported stock one still isn't as good as an out-of-the-box Edelbrock or Accel.
Old Sep 14, 2001 | 06:24 PM
Dan87IROC-Z's Avatar
I agree with Formul8. Its not worth your time. I would just buy the cheapest aftermarket base you can find, and if you don't think it flows enough, then you can always port that one out!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 14, 2001 | 10:29 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
What is a price range for a good baseplate and where could I get it from.
future mods:
Wifes new car:
future mods:
Old Sep 14, 2001 | 11:13 PM
Guest
Guest
Posts: n/a
The price range is all the same, about 400 bucks. As for which one, pick one it really doesnt matter much.
The stock base can be ported to flow more than an unported aftermarket base... now if you were to port the aftermarket base then it would flow more than any stock manifold could if you just open up the ports.
Old Sep 15, 2001 | 01:58 PM
formul8!!'s Avatar
Car: 2004 GTO
The basic design of the air passages make the stock piece terrible, ported or not.
Old Sep 15, 2001 | 02:04 PM
Guest
Guest
Posts: n/a
The aftermarkets I have seen arent much better except one, and its no longer made.
Nobody wants to address the 2 largest problems, the low port floor and the lack of a runner-base transition.
Old Sep 15, 2001 | 09:52 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Well, I recommend sticking to a fully ported base for a mild 350 or a hot 305, with like 'vette heads or something like that. If you plan on anything over 320HP on a 350, get an aftermarket base, and then you have a good flowing base you can take even more out of if necessary.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
