help with INJECTORS
Old Apr 1, 2008 | 06:31 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
help with INJECTORS
A couple months ago, I had a bad injector that was shutting down my car when it warmed up. I got it replaced...that was injector # 6. Okay, so here's my recent problem and I think it has to do with the injectors... the car runs, but the engine seems to pulsate and run a lil rough. running rich and struggles to accelerate when I put the pedal to the floor. (I know the timing needs to be set, but with this other problem, setting it to zero is making the car run worse) I just had the cat checked and had some exhaust work done last week that helped some problems i had. I checked the ohms on each injector after the car had been running for about 7 minutes. here's what I got and it doesn't look good:
injector #1 - 13.6
#2 - 11.7
#3 - 12.7
#4 - 3.2
#5 - 12.9
#6 - 16.8
#7 - 12.4
#8 - 16.8
obviously the #4 injector must be too low. what are they SUPPOSED to ohm out at HOT and at COLD? does anyone know? and should I get this injector replaced or is something else a cause of this? i'm afraid that if I let this go much longer, the car will start shutting down like it did with the 6th injector problem...and I gotta go out of town this weekend. can someone help me ASAP? thanks ahead of time for any input!
Old Apr 1, 2008 | 08:22 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: help with INJECTORS
should be around 16 anything below 14 is on the way out,later jimmy
Old Apr 1, 2008 | 08:31 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
so this is the reading I'm supposed to get when the engine is hot? what is it supposed to be at cold or is it pointless to check it at cold temperature? is it possible that the injector that is at 3.2 is causing the others to drop below 14 or should I just go on and replace all of them? thanks for your help
Old Apr 2, 2008 | 02:12 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Injectors are like tires, all are used the same and wear out close to the same.
The electric coils short a winding, that makes more heat, which shorts a few more, ect... till failure.
Also when the shorted coil is over loading the driver, it is causing the rest of the coils to run at a lower voltage(more heat).
Most people here just change them all.
Old Apr 2, 2008 | 03:32 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
3.2 is definitely too low, that injector is toast. Mine ohmed out (cold) at around 16 each.
Old Apr 2, 2008 | 12:15 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
since i should probably replace them all, should i be replacing that #6 too since I replaced it a few months back? and does anyone know of any racing-type injectors for a 305 TPI that I should put in it?
oh... ok i guess I will change them all.. anyone know of any good racing injectors?
Last edited by armygreen87; Apr 2, 2008 at 12:19 PM. Reason: Automerged Doublepost
Old Apr 2, 2008 | 12:37 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
https://www.thirdgen.org/forums/tpi/...injectors.html
19# Injectors should set you right for your 305 without a retune. Sadly enough, the SVO injectors are about as good as they get for this application. >.<
Old Apr 2, 2008 | 05:22 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
thanks a bunch, i will take a look!
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
