13.5 with stock tpi and heads
Old Sep 16, 2001 | 11:23 PM
JJ's Avatar
JJ
Here is the plan with my 89 L98 formula. I am going to do the engine later, when I can do it right. In the meantime I want to run 13.5. Here is the plan - port/gasket match stock intake, valve job/pocket port stock heads/screw in studs&springs to use 1.6rr's I already have, and a mild cam. I have slp exhaust(headers back) already, slp cold air, and rebuilt tranny with transgo and 2700 vigilante TC. Just bought bfg drag radials and will get suspension this winter. Paint will take up the funds next year, I just want to run decent until I can concentrate on the engine. Now that you have the foundation, who is running mid 13's on stock heads/intake. I'd like to hit 102-104mph.
This winter, along with the suspension, I'm also replacing the fuel pump, injectors, and water pump - I already have full MSD ignition also. I'll probably attempt to learn how to burn my own chip too.
Old Sep 17, 2001 | 12:34 AM
98_1LE's Avatar
It's all in the 60'. With a good converter, rear suspension and sticky tires, you should have NO problem running 13.5 or better on that combo. I have run 13.94@96.6 with a handful of mods: ported plenum, tubular LCA's & panhard, cheap B&M converter (~1800 foot stall), Nitto DR's, Hypertech chip, airfoil and SLP 2OTL muffler/tailpipes. This was with stock motor, exhaust back to the muffler, '87 TPI airbox etc. I cut a 1.95 60' (best of 1.89) and scored a good ET. I am hoping for a 13.6@100 with headers, high flow cat, 3" intermediate pipe and 1.6 rockers. Time will tell.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 17, 2001 | 06:11 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I agree, 13.5 should be possible. I ran 13.81@98.96mph with a 1.96 60ft time. That was a stock L98, ported intake, plenum, manifold, cold air and some good suspension mods. Track was sea level with good spring-time air.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Sep 17, 2001 | 11:44 AM
Bad Blk Z's Avatar
look at my sig. i run have run 13.6 with out even touching the motor, through stock manifolds. Get a set of M/T sportsman pros for at the track, put them at 16 psi and do a light burnout.
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Performance Resource chip
Centerline wheels
K&N, Gutted air boxes
Gutted cats
Best Pass = 13.710 @100
Best 60' = 1.842
on M/T Sportsman Pros
Race Car:
S/P 91 Camaro Z/28
454 LS7 crate motor
Crane Roler cam
Dart intake
1000cfm TRC Carb
Powerglide
9" Ford rear
Goodyear 14"-32"-15"
Weld prostars
All steal except for hood and rear deck
Best ET: 9.64 @ 145
3000# with driver
Old Sep 17, 2001 | 12:58 PM
IROCKER's Avatar
My hardest part is getting a good launch. With a 1.988 60' time I was able to pull off a 14.7 and a 14.8, and that was with very little slip.
If you can pull of a run with little wheel slip, a 13.5 should be easily attainable with the mods you listed above.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Sep 17, 2001 | 11:36 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
hmm...guess I shouldn't have complained.
I ran 14.20s at 97.55 cutting a 2.1 60 foot. I have SLP exhaust, no cat. That's all. With 148,000 miles. I don't see how hitting 13.5s without touching heads should be a problem. I believe someone said it above... it's all about traction. An E.T. is traction.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Sep 18, 2001 | 12:08 AM
JJ's Avatar
JJ
Thanks for the responses guys. With the vigilante, bfg drag radials I just bought, and LCA/brackets I will do this fall I should have a pretty good 60'. I just bought a tpi base so I can get to porting soon also !! Just need to pick out a nice mild cam now.
Old Sep 18, 2001 | 02:42 PM
86ZZ4's Avatar
Good 60 ft's is where its at.My Z 60 ft's awful on street tires 2.16 best,babying it for 30 or so ft and it shows in the ET.Now my AMX has less HP then the Z,stock 390 long block with the usual boltons for a carbed car ,(stock cam).With Sportsman Pro's its runs 12.94@102 on a 1.83 60 ft.It MPH's low cause it basically runs outa cam LOL.But you see what i mean. It screams the first half track,and that makes up for its lack of high end HP.
[This message has been edited by 86ZZ4 (edited September 18, 2001).]
Old Sep 18, 2001 | 02:46 PM
86ZZ4's Avatar
OPPS , Z28 spec in sig
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
