after ported plenum, now I get a dead spot
Old Sep 27, 2001 | 07:45 PM
jmon92conv's Avatar
after I ported my plenum the car runs great except when I accelerate out of corners. Being that I autocross, this is BAD. Everytime I nail the gas, I get a dead spot for just a moment. I have read about this before but forgot the fix.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Sep 27, 2001 | 11:50 PM
whiteroc's Avatar
The baffles in the gas tank are broken. Time to get a new tank... or you can always go around the track with a full tank of gas.
Old Sep 28, 2001 | 12:58 AM
fst5spd350's Avatar
You mean dead spots like the car slows down like it's out of gas? My car only does that when it's real low on gas. But only when I turn real hard. It does sound like the baffels are broke though. Tough luck man, good luck.
Old Sep 28, 2001 | 09:14 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Sounds like you need to increase your pump shot. See the PROM tuning board.
Old Sep 28, 2001 | 10:26 AM
Drakar's Avatar
Go with a fuel cell if you Xcross, unless it is also daily driven ..... are theer laws against fuel cells ... aren't they safer anyways???
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 28, 2001 | 03:14 PM
jmon92conv's Avatar
I really don't think it is the baffles. This is also a daily, and the problem really only occurs when I drive it hard. I always race with a full tank to help set the rear. it is just a kind of delay, like when you nail a 4 barrel carb.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Old Sep 28, 2001 | 03:15 PM
jmon92conv's Avatar
Oh, forgot to mention that I have the FP turned up to 46 lbs.
Jeremy
Old Sep 28, 2001 | 04:02 PM
86ZZ4's Avatar
Drive it with a Fuel pressure gauge on it and see what it does
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
sammy52401
Nov 11, 2015 07:20 PM
bigjay89gta
Oct 15, 2015 08:04 AM
toronto formula
19
Oct 6, 2015 12:27 PM
raymondandretti
Sep 27, 2015 06:43 PM
