19lb injectors from a 89 mustang...good?
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
are these better then my stock 19lbs?
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 19lb injectors from a 89 mustang...good?
any slowstang, rustang, mistake (etc etc) part on a camaro is a sin
i know that dont help any but i had to say it
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
I'm not sure, but I think 19# injectors all flow the same regardless of the make. My understanding is that the number is the amount of fuel they flow.the higher the #, the greater the flow rate.The only differance might be the Ohms, which could cause drivability issues.
thanks, but coming up with cute names for mousesangs
is not what i had in mind. its just that i read somewhere that they actually out performed and out flowed what came stock on the LB9's. well at least ford did one thing right....they circled the problem
i can get a new set for just about nothing. apperantly ford under rates their injecter sizes?
Car: 89 iroc
Engine: l98
Transmission: tremec
first of all Ford does not make an injector.. They use Bosch to make the early stang 19's and now seimens make the new ones. However ford uses rail pressure of 37-39 when they came out with the first yellowtop injector back in the early 80's. these injectors flowed a little over 19 at that pressure. at our pressure they flow a little over 21. the stock 305 injector is 19 lbs .. the o2 sensor will compensate for the difference. On the 350 these injectors flow the same as the stock multec which also is a little under 22. All i know is that since i put the bosch design III's in my car--it runs great. I can honestly tell you that these are much better than I thought they would be. They are easy to install and really worth the 169 for the whole set.
i got them at www.fuelinjectorconnection.com
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I got mine off ebay, for $65 shipped. They've been cleaned and came with new o-rings (although I used GM o-rings). I'm not positive that these are the same ones that would come on an 89 mustang, but I think they are. They are 19# bosch ford design 3, with the 4 hole nozzle. They fit very nicely, just make sure and use the injector clips to put them into the fuel rail. They're slightly shorter than the GM ones, and without the clips, they will go too far up into the fuel rail. Here's what they look like installed:
I haven't run them yet, I'm putting the engine back together today. irocuroc hit the nail on the head too about the rating differences, ford runs them at a lower pressure. I'm putting these on my 305, hopefully the o2 sensor will adjust for them, until I can tune for higher flow injectors.
If it makes you feel any better, technically they are bosch parts, it just so happens that ford uses them
Car: 89 iroc
Engine: l98
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I am looking for sum good injectors, I have a holley stealth ram and the TPI injectors are too tall. I want 24 lb. The harness I bought has a different style connector for the injectors, any help?
Car: 89 iroc
Engine: l98
the only thing i know is to call jon sr at FIC he knows all about this stuff
770 888 1662
770 888 1662
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I called Jon jr and got ALL the info I needed, they are experts at what they do, I ordered the design 3 for 169.00, with a three year warranty, they are Bosh 60mm EV6 connectors, thanks for the info.
Car: 89 iroc
Engine: l98
so they make a design 3 with the oval connectors. thats very cool. how did you get that connector anyway. i thought all the harnesses come with the plug like on the car stock..
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I've been running a set of 19# Bosch/SVO injectors for couple years now. No problems at all.
They supposedly have a better spray pattern, and the junk yards are full of them, cheap.
Ron
Ron
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
When I ordered my harness from Affordable fuel injection, they built the harness with the EV6 connectors, with injectors to match. I also found out that 24lb injectors are too big for my ride.
thejimsterz28
Sep 15, 2015 04:37 PM
