Throttle Body
Old Apr 20, 2008 | 01:57 AM
JODYP1's Avatar
Throttle Body
I have antifreeze running out of the inside of the throttle body and also flowing throught the tuned ports into the heads and out throught the headers. My car is a 85 Trans Am with a 88 Corvette L98 that I just installed. What is the problem? I mean it only took about 30 seconds or less to dump out all of the coolant I just installed. Please help any advice is greatly appreciated.
Thanks in advance for all the help.
I did a search but I did not find the answer to my problem unless I overlooked it
Last edited by JODYP1; Apr 20, 2008 at 11:39 PM. Reason: Problem resolved. Praise the Lord.
Old Apr 20, 2008 | 11:31 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: Throttle Body
there is a hose that hookes up to throttle body that has coolant running trough it and comes out on the other side. You can bypass the throttle body if somehow it was ported and here is a hole or something. But are you sure it goes from the throttle body?
Old Apr 20, 2008 | 11:40 PM
JODYP1's Avatar
Re: Throttle Body
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
