Another injector problem..........
Old Oct 9, 2001 | 08:12 PM
Jeff 91Z28/L98's Avatar
OK, I had 2 stock injectors that were bad so I bought the #23 Accel's and installed them. The car would idle/run like crap and stall at a light. The fuel pump did its thing when the key was turned on. The fuel pressure is set at 48 psi and remains steady. I tested for any codes, none. So I took the Accel's back out (PITA) and bought 2 new stock injectors ($85 a piece) and reinstalled all the stock injectors. Now it's not missing a beat but I'm not satisfied about the new Accel's not working. Any insight out there besides selling the Accels to someone?
1991 G92 Auto L98 - 3.23 71,000 miles
BBK 52mm Throttle Body, Ported Plenum/Runners, Edelbrock TES Headers (JetHot coated),
Dual Cats, American Thunder 80 Series Catback,Accel Wires (8.8mm), 160 Thermostat, TPIS AFPR (48psi),K&N Air Filters.
Rebuilt 700R-4. Thanks "Transfixleo".
1st time at the track, guess I should learn to launch right.
60ft: 2.15
Qrtr: 14.20
MPH: 98.49
http://www.geocities.com/ssgtmcmichael/.html
Old Oct 9, 2001 | 09:17 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I just ordered the same injectors. I hope I don't run into this problem. I was thinking maybe if you set the fuel pressure down that it would help. You would already be getting the extra fuel needed with the bigger injectors. Just guessing.
Old Oct 9, 2001 | 10:00 PM
u r sofa king we tah did's Avatar
injectors need to be matched in 8's. 8 bosch stock 22#, or 8 stock 23# accel. not 6 of these, 2 of those. or vise versa. perhaps that was your problem
Old Oct 9, 2001 | 10:20 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
<font face="Verdana, Arial" size="2">Originally posted by u r sofa king we tah did:
injectors need to be matched in 8's. 8 bosch stock 22#, or 8 stock 23# accel. not 6 of these, 2 of those. or vise versa. perhaps that was your problem</font>
Reread his post He didn't mix them. He reinstalled all the stock ones.
Old Oct 9, 2001 | 10:47 PM
airdeano's Avatar
jeff,
i ran into the similar problem, but we had no
running for our injector replacement. found
out that MSD 26# injector @ 2ohm is too much
injector for a stock ECM setup. stock injector
resistance should be 14ohm cold.. 16-17ohm
hot. the ecm can only take so much direct
that if too direct malfuntions occur.
swaped for some accel 26# and 14ohm worked
like a champ... measure the resistance
in those injectors.
airdeano
Old Oct 10, 2001 | 12:23 AM
my fault. i just skimmed over it and thought he wrote he replace two bad ones with two new accel injectors. damn and i just ordered some accel injectors, hope they work right. although, 48psi is pretty high. dont know if it would cause that big of a problem though
[This message has been edited by u r sofa king we tah did (edited October 09, 2001).]
Old Oct 10, 2001 | 01:37 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Did you have an eprom set for the larger injectors? By design, the stock GM eprom is already too rich, plus you are running a high fuel pressure. I have found that even though injectors MAY be rated close to the stock GM (23 vs 22), the injectors often will flow more than GMs rating.
My guess is you were running too rich, and it takes the engine a few minutes of running (and moving) before it will go into closed loop. If you were just letting it idle, then you didn't even hit closed loop and were relying solely on the eprom, which for SD cars are critical.
Old Oct 10, 2001 | 07:58 AM
I've talked to a couple of guys on the board who've had no problems with there #23's, but it could be something I neglected to check/do/or not do. Who knows, I got all winter to figure it out.
I checked the resistance of the Accel's before installation and they were at 14.2ohms(cold) and 16.1 to 16.2(hot).
GLENN, I didn't have the EPROM set for larger injectors. All I have is the Performance Resource Chip and calpac. I tried the stock chip then the Hypertech chip and finally the PR chip, none solved the problem (may need a custom chip burnt). It was running way too rich (could smell the fuel). The thing is I wasn't setting any codes and so it was throwing me off (not hard too do) .
I'm going to reinstall the Accel's again and dial the fuel pressure down to at least 40 psi and work my way up (testing the drivability with each lb of pressure increase). If that doesn't work then I'll just take them back out and wait until I get the ATI Procharger installed and then try them. Thanks to everyone that replied
Old Oct 10, 2001 | 08:44 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Honestly, i really doubt the increased flow would make it run that bad, unless perhaps the ignition is also weak or something else was contributing to it. Reason being, i was running my LB9 @ 56psi for a while, even with the stock chip for a couple weeks before my burner came in. It drove perfectly fine even though it was bottoming the BLMs.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
