Some Heads
Old May 16, 2001 | 08:38 AM
Steve89GTA's Avatar
Some Heads
My girlfriends dad has got some heads lying around from a 350 he had pulled out of a blazer. The heads are IRON not alumn. Would these heads do me any good on my 305tpi car (install a cam as well).
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 16, 2001 | 11:27 AM
mirage2991's Avatar
no because you have 58cc chambers where the 350 has anywhere from 64 to 76...you are not saying what # those heads are, if they are 882's they are 76cc smoger...they suck...I have those...they suck...but anyway, you cr would go down dramatically, thus you would loose hp, even with any flowing increase...I heard that the sportsman SR torquer heads are made for 305 and works good....or you could have those heads machine to come out to 58cc, but then, I'm not sure if for the amount of work there is to change heads and have them machine that the performance will justifies the headecks...my theory on heads is go aftermarket to get the most increase and do it once.....
Old May 17, 2001 | 07:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually the iron TPI heads are 64cc, but if the heads from the 'blazer' are 64cc you probably will still lose power because the TPI heads are actually one of the best stock iron heads (besides vortec which soean't fit anyway)
Even if they have 2.02/1.60 valves the TPI heads stock to stock are better. Now if they are aftermarket iron or are fully ported/worked stockers the story's different.
Old May 19, 2001 | 05:32 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
what do u think r the best aftermarket iron heads?? i am seriously considering the 350 S/R torkers. 170cc runners 67cc chambers i am also doin cam and headers in the package. the intake is stock xcept for porting the plennum...
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old May 19, 2001 | 11:17 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
NO NO NO NO NO!!!!! can we please make a permentant link on the home page of this site as to why S/R torquers and World product heads in general SUCK!!!!
In short if u want the best cast iron head, buy some Dart Iron eagles. Please click the link below to see why i say World sucks. Im now on a mission to inform everyone on the Thirdgen.org TPI board that World heads suck. https://www.thirdgen.org/messgboard/...ML/002513.html
[This message has been edited by 88blkiroc (edited May 19, 2001).]
Old May 19, 2001 | 02:38 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Quote: World product heads in general SUCK!!!!
I would like to mention there are many points to consider when selecting cylinder heads. You CAN NOT take one measurement, flow, whatever and take that as bible. Unless you have many years of cylinder head porting WITH use of a flow bench access (and you know how to use it correctly), you should be selective in your comments.
As I recall the WorldProducts heads have been around for a while. But they are inexpensive and they WILL AND DO outflow stock heads. So for the enthusiast who wishes to replace a tired set of 305 heads, these are a good place to start.
I would agree that if you are after some higher power on a large cube engine, then you might want to broaden your choices for cylinder heads.
With any cylinder head, if it comes without any porting or cleanup, there can be lots of casting flash and core shift. I recall a set of iron eagles that I was not too impressed with.
All in all, make sure to consider all items and cost. I selected Edelbrocks for my engine (very nice pieces). Above and beyond the cost of the heads I needed rather pricey head gaskets, hardened push rods and special head bolts (requires a washer). Heck new head bolts are always a good idea.
When selecting a head, I would look for the smallest intake CC volume and the highest flow. The smaller the CC, usually the higher the velocity. Make sure to look for high flow that complements the lift of your cam (no sense buying a head that flows well at 0.600" lift if your cam is only 0.454").
Mark.
Old May 20, 2001 | 05:30 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
the cam i chose is relatively mild .460 lift.(daily driver) the only other mods planned r headers. intake is bone stock besides cold air intake and ported plennum.so i figure heads with large intake runners will do me no good.my goal is to make 300hp from my L98.should i just leave the stock heads on it.(rebuilt 14months ago) and get the ponies elsewhere.?.SLP runers,ignition, pullies,
Old May 20, 2001 | 04:16 PM
JoelOl75's Avatar
The s/r is just short for 'stock replacement'
doesn't inspire thoughts of horsepower building....
Now trick flows $850 tag is sounding good to me and they're good to .510 lift although i'm thinking the extra cash for the bigger valves might be a better investment.
I'm in te middle of a buildup from hell (all I have is the short block dissasembled, valve covers, and a timing chain cover!)
I have to find a way to get that **** finished cheap and quick and so far the parts that seem to really be laying the beatin into me is finding a serpentine setup from the junkyard.
Old May 21, 2001 | 05:28 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
trick flows for 850$ hmmm where at? and r they emmisions legal?
Old May 21, 2001 | 06:09 AM
poncho9789's Avatar
For a 305 why not get a pair of 350 heads from a L98 and port and polish the heads (int.and exh.) and a 3 angle valve job. That would give you more than enough flow at a cheep price.
Old May 21, 2001 | 08:08 AM
JoelOl75's Avatar
Actually for a 305, get the LB9 heads, they have a 59cc chamber and wont dump the compression of the 305 in the toilet.
The trick flows 23 degree can be had at... http://www.summitracing.com
I swear these companies should give me a discount. I like summit for some things though, jegs for few, and the junkyard for most.....
Old Oct 9, 2001 | 03:39 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Dude, getting heads from your girlfriends dad is not cool.
Old Oct 9, 2001 | 03:58 PM
lexussc94's Avatar
I think you wanted to say....
Dude, getting head from your girlfriends dad is not cool.
Old Oct 10, 2001 | 02:40 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
<font face="Verdana, Arial" size="2">Originally posted by eddie89TA:
</font>
http://cgi.ebay.com/ebaymotors/aw-cg...item=596535128
Old Oct 10, 2001 | 02:44 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
I just put on WP S/R 305 Torquers and must say was very impressed with the improvement. $700 for new heads, higher lift ability, and 30 HP... how can you complain?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
