engine stalls when cold
Old Oct 17, 2001 | 10:11 PM
Ziimo's Avatar
when i start the motor it will start fine idle for a sec and stall. if i pump the gas it will run but very ****ty and will eventually stall if i let off the gas. also backfires once and awile and has very bad hesitation until it warms up what would cause this engine is 85 tpi with headers.any help is greatly apreciated. thanks Z
Old Oct 17, 2001 | 10:40 PM
airdeano's Avatar
is this a first start in morning or does
this happen when eve you start it.
possible coolant temp sensor defect, MAF power
relay, or a vacuum leak.
just some suggestions. a scanner should be able
to watch the fuel mixture during start up.
airdeano
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
