Throttle Body Blades
Old May 2, 2008 | 01:44 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
This is an update to "Another Idling Problem" post. So the throtle body is at the machine shop right now getting new bushings installed for the butterfly valve shaft to correct the vacuum leak. I will post any interesting information regarding this procedure here.
However, I heard that once you have the throttle body off grinding the bottom of the throttle body blades thickness from about 1 mm down to a sharp edge improves air flow I guess especially during wide open throttle. I did a search and found no information on this subject. Do after market Holley, BBk, Edelbrock, etc. make this modification to the throttle body blades?
Old May 2, 2008 | 02:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Throttle Body Blades
Sorry never heard of that
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
