LT4 intake
Old Oct 19, 2001 | 05:36 AM
BV1's Avatar
BV1
LT4 intake
Link for new LT4 intake manifold modified to fit LT1 ($249.00). I've emailed them for the cost of drilling the distributor hole, but no response.
http://www.lapracing.com/lt4-intake.htm
Brian
Old Oct 19, 2001 | 09:44 AM
Formula-91's Avatar
There you go. Buy the manifold, send it to John to be converted, and away you go...
Still cheaper by far than a Miniram...
Old Oct 19, 2001 | 10:13 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
That's the route I think I'll be taking....only a few bocks more than a used LT1 too....
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
[This message has been edited by Ed1LE (edited October 19, 2001).]
Old Oct 19, 2001 | 05:18 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
dont bother find a junked taxi or police cruiser rip the lt1 off of it have it extrude honed.it'll outflow the lt4 for around the same price
Old Oct 20, 2001 | 03:09 PM
Tas's Avatar
Tas
used LT1 intake = $50. Does the LT4 intake come with fuel rails? LT1 intake with fuel rails $110. New Holley multi port intake $255, $220 something with that 10% off summit thing floatign around. http://www.holley.com/HiOctn/ProdLin...901-101-1.html
-Tas
'89 Formula WS.6
Got Beach?
[This message has been edited by Tas (edited October 20, 2001).]
Old Oct 20, 2001 | 07:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Does that Holly thing come with fuel rails? No.
Does that Holly thing come with a throttle body?
No.
Lt1 intake you can use your existing TB.
Old Oct 20, 2001 | 08:28 PM
Tas's Avatar
Tas
Does that LT1 thing come ready to bolt on? No.
Bolt on with any machine work? yes.
Holley intake you can use your existing TB with a eblow from Accel, or you can use a TBI without the injectors, or you can get creative any modify a 4 barrel to 2 barrel car plate adapter to bolt the TB on.
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 20, 2001 | 08:30 PM
Formula-91's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
Yup. The you've got to come up with 2 grand for the rest of the system. TB, Fuel rails, Injectors, ECM. No thanks. I've already got an ECM in the car that is doing nothing but running VATS. Might as well put it back to work.
Old Oct 20, 2001 | 08:59 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
if you are gonna get that creative using the holley intake,i'm sure you can use a drill and spend the few bucks on a bit or two so the lt1 will work.either way you are gonna spend money as i'm sure it's easier to burn a prom for a manifold design that came from thee factory as opposed to the aftermarket.
Old Oct 21, 2001 | 07:22 AM
BV1's Avatar
BV1
I was origally going with the holley intake, but was concerned with flow numbers (406 project).
Link with interesting discussion on efi manifolds. Doug F works for Holley.
http://forums.chevytalk.com/forums/F...ML/000016.html
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
