LB9
Old May 6, 2008 | 07:28 PM
RicksIroc86's Avatar
Car: 84 camaro z28
LB9
i am going out to look at a 91 camaro tommorrow its got the 305 TPI. how do i tell if its got the 205 HP motor or the 230 HP?
thanks, rick
Old May 6, 2008 | 08:04 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Re: LB9
TPI or TBI.
Tuned port = rocks socks
TBI = get smoked by a civic.
Old May 6, 2008 | 08:17 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: LB9
Or..if it's auto or manual. Auto is the 205 HP, manual is the 225 HP.
Old May 6, 2008 | 08:57 PM
Car: 84 camaro z28
Re: LB9
oh well **** ok its an auto. i know its TPI tho
thanks
Old May 7, 2008 | 04:46 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: LB9
Look at the tac. The LB9 that got the cam from the L98 will have the yellow line at 5000 RPM and red at 5500 RPM.
Old May 7, 2008 | 08:34 AM
Car: 84 camaro z28
Re: LB9
ooooooooooh ok
that makes sense
thanks alot
Old May 7, 2008 | 11:08 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: LB9
1 or 2 cats?
Old May 7, 2008 | 11:38 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: LB9
The cat could of been replaced... as with my 91 formula... it had 1 when I got it, but after checking the vin with a dealer, I was told it was originally 2 cat...
It's a 5 speed tpi, so it has the L98 cam... and fun too
Raf
Old May 7, 2008 | 03:58 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Re: LB9
Ok an argument will start here considering some say my 91 auto lb9 got the l98 cam and some will say it got the peanut cam regardless of what the tach says.
Old May 7, 2008 | 08:48 PM
Car: 84 camaro z28
Re: LB9
ok well on the hpone the guy told me it was fuel injected but it turns out it is the LO3. but i bought it anyways cuz it was 1600 bucks and it runs good.
thanks for the help tho
Old May 8, 2008 | 01:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: LB9
All the L03's are TBI with the "peanut cam" and 170 HP.
The 205 HP 305 TPI's have a single cat system and a 2.25" cat-back exhaust, same as the TBI engines. The 230 HP 305 TPI's have the dual cat system and a 2.75" cat-back, same as the 350 engines.
Old May 8, 2008 | 07:40 AM
Car: 84 camaro z28
Re: LB9
oh so the reason why TBI is slow much slower is just the cam pretty much?
Old May 8, 2008 | 09:04 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Re: LB9
More the exhaust than the cam.
Old May 8, 2008 | 09:33 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Re: LB9
no more the fuel injection.
intake.
Old May 8, 2008 | 08:04 PM
Car: 84 camaro z28
Re: LB9
oh ok
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
gta90
Sep 15, 2015 04:00 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
happyhapka
Aug 15, 2015 04:42 PM
