Hard to start...
Hard to start...
Ok, this has been happening off and on, very spontanious and not consistent. Like last night for example (please bear with me)...I've was driving around a bit, some highway and some city driving and we went to park and chat. Then after about 10-15 minutes, I hop back in my car and go to start it up, and it cranks and it cranks. Dammit! I try it again and same thing, it cranks and cranks and finally starts to catch, sputters a bit and then stalls. It did this two times and then finally started up but was running like crap till it ran for a bit. We drove a short distance, parked again for a chat and the same thing happened.
A couple things I noticed:
- the starter cranks ok and is only a few months old
- the engine when it finally did catch on seemed to be running rich for a short while (strong smell of fuel)
- I can hear the fuel pump running
- it was a little damp last night, I don't think that can affect a TPI motor, but I just thought I would mention it
Any help or hints you guys can give me would be great. I do have Craig Moates software and the ALDL cable to scan the car if anyone knows what I should be looking for. Thanks in advance for anyone that can help.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
1987 Camaro IROC-Z
2001 Sunfire GT
sounds like your fuel injectors may be breaking down. check the resistance across the poles with an DMM. they should read around 14-16 ohms cold. if they are lower they may be starting to break down. once they heat up, the resistance will lower, and the injectors will stay open longer, causing hard starting, poor fuel economy, and maybe even rough running if they are getting bad enough.
Check you fuel pump ground. Sounds like your fuel pump is going bad to me. Don't know if you have a fuel pump relay. Check if you do.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
The Phoenix Project..click to see my project carTrans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
I will check the resistance on the injectors...do you have any instructions on how to do this? I would be very appreciatative
mtccl: Where is the fuel pump ground? Yes, I have a fuel pump relay and it should be good. It's not that old.
Thanks guys, if anyone else has any suggestions I am all ears
1987 Camaro IROC-Z
2001 Sunfire GT
1987 Camaro IROC-Z
2001 Sunfire GT
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
To check the injector resistance, unplug the harness from the injector, touch the DVM (Digital Voltage Meter or something like that) probes to the 2 prongs sticking out from the injector, and measure the resistance in ohms. My SVO injectors were all either 16 or 17 ohms to give you a range to work with.
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
That's cool, I can manage to check that easy enough. Around 16 ohms eh? How much resistance should that have when they are cold? Is it the same?
The leak down test...can this be done using the valve on the passenger side of the fuel rail and a fuel pressure tester?
1987 Camaro IROC-Z
2001 Sunfire GT
1987 Camaro IROC-Z
2001 Sunfire GT
I just checked the resistance of the injectors and at cold they were all 16.8 except one was 16.7. I went and drove around the block for about 10 minutes and let the car warm up. Then I checked the resistance again and they all about 17.2-17.3. How much of a range is allowable? And is it bad for the injectors to be higher than 17 ohms?
1987 Camaro IROC-Z
2001 Sunfire GT
1987 Camaro IROC-Z
2001 Sunfire GT
Does nobody know the acceptable ranges?
1987 Camaro IROC-Z
2001 Sunfire GT
1987 Camaro IROC-Z
2001 Sunfire GT
Engine: 385 HSR
That's about the range mine are in. Nothing out of the ordinary with only a .1 ohm difference. One or more injectors could still be leaking through since it sounds like your engine's getting flooded.
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
RedLeader289
May 28, 2019 01:47 PM
