305 TPI smoking and leaking tons of oil
Old May 25, 2008 | 05:48 PM
86bird86's Avatar
I have an 88 trans am 305 TPI that has just started smoking out of both valve covers but mostly the passenger side. I can see oil coating the entire underbody of the car including all over the catylactic converter. I don't know where the leak is coming from and ive noticed the hose keeps popping out of the passenger valve cover. Any help would really be appreciated.
Old May 25, 2008 | 08:51 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Re: 305 TPI smoking and leaking tons of oil
Seems like you have a ton of blow-by. Bad rings?
Old May 25, 2008 | 09:12 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
sounds like u have a ton of blow by. for now get some 50 weight oil to slow the leak down
Old May 26, 2008 | 06:53 PM
86bird86's Avatar
what is blow by? Is it a serious problem or an easy fix?
Old May 26, 2008 | 07:16 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
blowby is when the oil from your pan "blows by" your rings into the combustion chamber and then gets burned with the fuel.
It's pretty serious and at the LEAST requires re-ringing the pistons, and more often a full rebuild including re-boring the cylinders and getting larger pistons to fit.
Old May 26, 2008 | 07:18 PM
86bird86's Avatar
How long could I get away with driving it the way it is? Or would I be causing more damage?
Old May 26, 2008 | 07:25 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
My bad I was backwards, blowby is when combustion gasses get into your oil pan, not the other way around, and it causes alot of pressure in your valve covers pushing oil out from the seals.
No clue how much potential damage it could cause.
Old May 26, 2008 | 07:35 PM
86bird86's Avatar
is it possible that this is just a simple oil leak? it seems to be running from the engine down over the under floor,exhaust, and converter. The smoke coming from the hose on top of the valve covers has me wondering though.
Old May 26, 2008 | 07:53 PM
87SSTPI's Avatar
The fact that you are blowing the hose out the PS valvecover points to excessive pressure in that area.
Old May 26, 2008 | 07:56 PM
86bird86's Avatar
An engine rebuild is the only solution?
Old May 26, 2008 | 09:52 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yeah pretty much but like i said a temporary solution would be to put 50 weight oil in.
Old May 27, 2008 | 06:40 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
buy a good used motor and put it in
Old May 27, 2008 | 08:31 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
^^yeah thats your best option its not worth the time/$$$ to rebuilt a 305 tpi, you could pick up a cheap carb'd 350 and drop that in and be haulin ***. check craigslist.
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
