Good info on stock airbox vs cold air intake
Old 05-29-2008, 10:56 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I was at TPIS awhile back and they were testing the stock airbox to see what its limited to. With a gutted air box and some kind of hawks ram air boxes, and a gutted maf, the air box runs out of air around 425 hp. Anything above that you should use a 3 inch cold air intake. June 28th when I go to the track I am going to test both methods to see which on yields better results.
Old 05-29-2008, 11:30 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Good info on stock airbox vs cold air intake
Did they happen to list CFM numbers? I cant seem to find that info for a camaro lid/intake. Just the firebird setup which is totally different.
Old 08-11-2010, 03:31 AM
thegooseman's Avatar
Car: 1992 RS
So what happened? I cant find anythreads with somebody testing both style intake systems. All I can find on here are opinions and no real testing that has been done.
Old 04-07-2011, 08:08 AM
Guest
Guest
Posts: n/a
I agree with THEGOOSEMAN... everyone says their opinion on stock snorkel setup vs the aftermarket single intake. . We need real test info .. not opinions.
Is cutting the maf screen a good safe idea? People say that you get slightly better air flow but will it mess with the motor?
Old 04-07-2011, 08:48 AM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
I built my own custom cold air intake with 3.5 inch aluminum tubing, and I did notice a difference in high RPM pull. As for cutting the mesh screen on the MAF, I personally would not do it because, 1) I don't see how you would get more air flow and 2) if you manage to break the sensor they are very expensive to replace.
Old 04-07-2011, 09:22 AM
Guest
Guest
Posts: n/a
Are there any test results from the stock snorkel air box gutted vs a single aftermarket intake?
Interested in knowing the difference if any... I have the stock snorkel set up in my garage and the single aftermarket intake on the car now... cant tell a difference personally. but maybe if i gutted the stock snorkel set up i would?
1992 Trans Am
05-10-2023 07:19 PM
Jake_92RS
08-11-2015 10:39 AM
bryan623
08-10-2015 11:33 AM
Quick Reply: Good info on stock airbox vs cold air intake
