Need help on what kind of cam
Old Dec 13, 2001 | 12:40 PM
1986CamaroIROC-Z's Avatar
I am lookin to buy a 350 shortblock...probably the L31
http://www.sdpc2000.com/cart.asp?act...id=514&pid=621
My question is what kind of cam do I use, the hydraulic roller or the flat tappet. Does it depend on the heads I buy? I need help in buildin my engine.. I plan to keep the TPI if it helps at all.
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Dec 13, 2001 | 12:56 PM
ImportsRsloths's Avatar
i like the ZZ3 and ZZ4 cams
88 Iroc-Z L98, rebuilt T5, ported manifold and plenum, built 355 shortblock, ZZ3 cam, Ported S/R Torquer Heads (2.02/1.60), AFPR, Hedman 1 5/8" 3" collector, 3" y pipe, !Cat, Edelbrock Catback, 3.42 gears WAITING FOR TIMES!!
Old Dec 13, 2001 | 01:32 PM
tpi_roc's Avatar
Depends on the year of the block first off, so you know if you're going flat tappet or roller, if its a flat tappet block you can buy after market roller lifters at about $350 a set.
If its a 350 the general rule is to stay under .220 duration @.05, as much lift as your valve train can last (not over .470 stock) and your lsa from 112-114 for tpi, on carb you can go under 112 but that will be fairly radical.
1985 Iroc-z, 14 second 305, new engine in the works.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
