increasing air, how to increase fuel??
Old Jul 4, 2008 | 02:48 PM
89Formula_350's Avatar
Car: 89 Formula 350 Firebird
Engine: L98 350 TPI
Transmission: stock auto
I have an 89 Formula 350 Firebird with the stock 5.7L TPI. I have a few ideas for increasing air flow ... headers, cat-back exhaust, and also something on the intake side like a K&N unit, throttle body air foil, mass air flow senor, or even having the TPI plenums grinded ... but I have no clue what I SHOULD do on the fuel side OR what I NEED to do on the fuel side. Will my stock fuel system be able to deal with the increased air flow? Will I be wasting my time focusing only on the air flow and neglecting the fuel system? Thanks for any help!!
Old Jul 4, 2008 | 03:35 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Re: increasing air, how to increase fuel??
Everything you have planned to do wont be enough to get bigger injectors or increase your fuel pressure. Once you put in a bigger cam and bigger intake you have to start thinking about the fuel side. Exhaust, plenum porting, and k&n filter will just help the engine flow easier. Your ECM will be able to compensate for the small amount of more air.
I have heard the air foil really isnt worth getting.
Old Jul 4, 2008 | 05:16 PM
Engine: L98 350 TPI
The air foil is not really worth getting??? But the catalog said it would work great ... especially with another couple of items from the same manufacturer =)
Thanks for the info and the heads up.
Old Jul 5, 2008 | 10:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
more fuel has one love
more spark power
Old Jul 5, 2008 | 01:50 PM
Engine: L98 350 TPI
So I take it you are saying that if I increase my fuel pressure, I will need to increase my spark power, right?? Taking the advice from Cambridge 205, I will keep my fuel stock until I put in a new cam, which is a part of my plan eventually. Do you have any ideas for spark?? I was actually thinking about working an MSD system in my mod plan.
Hey Cambridge 205, I notice you have an 89 GTA with the L98 350. Your car is pretty similar to my 89 Formula 350. Do you have any insights on what mods I should start with?? Mine is bone stock and I am just starting to think about juicing it up.
Last edited by 89Formula_350; Jul 5, 2008 at 01:53 PM. Reason: Automerged Doublepost
Old Jul 5, 2008 | 11:17 PM
SmokinMyTires's Avatar
Car: 89 GTA, 89 Z-28, 96 Firebird
Engine: 5.0 TPI, 5.0 TBI, 3.8L
Transmission: stock 700-r4
Axle/Gears: stock
I know there are tons of posts and threads that contradict eachother on the subject of an airfoil. I bought one from TPIS for about $40 including shipping. They say you get 7-12 hp, thats max hp at around 4000-5000 rpm. Running at idle, my car (1989 GTA 5.0 TPI)did feel more powerful, not extremely, but you could tell there was a difference. BTW this mod isnt meant to be a single thing that solves power seekers problems. If you get a 3" exhaust mandrel bent, and a cold air intake, the engines breathing will be much cleaner. Here is a link to flow tests done that show the differences of cfm with different size throttle bodies, and with and without an airfoil. If you take the difference of a stock TB with and without an airfoil, its about 40cfm, exactly what TPIS said. Just my .02 cents.
http://dtcc.cz28.com/flow/index.htm
Old Jul 6, 2008 | 01:41 PM
Engine: L98 350 TPI
Thanks for that advice. Somehow this thread has shifted from whether or not I need to increase my fuel to the airfoil issue. I acutally have another thread over in the aftermarket product review section about the airfoil and you are right, I am getting some conflicting advice. I was pretty much thinking that for 40 bucks, it would be worth a try. I was going to combine it with other mods anyway. But you mentioned a cold air intake ... K&N doesn't make a kit for either of our cars ... I think ... at least not my 350. Is there a kit out there that has the panels that block the filter from the rest of the engine compartment??
Old Jul 6, 2008 | 02:03 PM
Axle/Gears: stock
I realize that you dont want to have a sirfoil argument thread, and neither do I. I tried tons of people for CAI, K&N, Airraid, SLP, nobody has one and if they do, its 300 bucks. I think it is probably fine if you make your own like this guy did,(check the link) but I bought one from ebay for $70. It isnt a perfect fit, but it works. I think its not meant for a MAF setup, but you can make it fit.
https://www.thirdgen.org/forums/afte...-cold-air.html
This is where I found mine on ebay. You have to search the pages below
http://stores.ebay.com/BestCarPart_C...QQftidZ2QQtZkm
Old Jul 6, 2008 | 04:56 PM
Engine: L98 350 TPI
Thanks. That may be the route I have to go. The link you provided took me to BOMZ's Ebay page. I did a search for "firebird cold air intake" and they actually do have a kit for 88-89 pontiac firebird, formula, trans am & GTA with the 5.0 or 5.7 TPI. It is 50 bucks plus 22 for S&H. This is the first kit I have ever seen for my car. I wonder if it is worth anything.
Old Jul 7, 2008 | 08:00 AM
jamon8's Avatar
Engine: 350 tpi
they are all gymics unless you put them on a
BUILT
motor
Old Jul 7, 2008 | 06:22 PM
Engine: L98 350 TPI
jamon8 ... this may be a stupid question that proves how much of a beginner I am when it comes to modding cars and the aftermarket, but what do you mean by a "BUILT: motor ???
Also, you last reply to this postmore ... "fuel has one love
more spark power" ... from what others have been telling me, I don't need to worry about increasing my fuel pressure until I put in a more aggressive cam. At that point, do you have any suggestions for increased spark?? I was thinking about an MSD system of one type or another.
Old Jul 7, 2008 | 11:06 PM
Car: 89 GTA
Engine: L98 350
You can do a tune up. New spark plugs, wires, cap, if you want new coil that will help spark OR do that and get an ignition box.
What I did was look for a coil that put out the most volts and I found a hypertech kit (coil, cap, rotor) heres a link to its summit page http://store.summitracing.com/partde...30+4294908198+ I don't know if this is the best anymore I don't even know if it was the best when I got it. But it's better than stock. I plan on getting an ignition box some day.
For our engines I would do the mods on this page https://www.thirdgen.org/tpimod1 I did most of them and avoided the MAF mod. For a cam I got the ZZ4 cam. From what I hear they work real good with our engines however it depends on how much power you want... But I don't know how much they are helping because I'm having trouble getting my ecm tuned. I wish I did it your way and put them on slowly and see the benefit's of each but when the engine went out I just put all the mods on at once.
After all the mods off that page but before a cam you might want to think about increasing fuel pressure on the AFPR do this with a ALDL cable and a datalogger by watching your blms and all that stuff. You can buy a ALDL cable or make one your self. I made mine my self. wish I had a link for you about that but I don't think their is one...
P.S. I didn't mean to start an air foil argument it's just what I heard... I'm sure some day I'm going to get one just to see if they really do help or not.
Old Jul 8, 2008 | 07:30 PM
Engine: L98 350 TPI
Don't apologize about getting on the air foil topic. I got a lot of views on it. Bottom line for me is that $35 is worth it just to satisfy my curiosity. The air foil is listed on the suggested mods link you provided, which is great, by the way. I am going to use that as a checklist as I go.
customblackbird
Aug 15, 2021 10:16 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
evilstuie
Feb 28, 2016 03:33 PM
forstral
Aug 19, 2015 03:20 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
