Annoying Idle problems
Old Jul 20, 2008 | 03:06 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
Ok i have an 85 IROC 305 tpi automatic.
the car hauls *** while moving you tap the as and it breaks your neck.
but when i'm coming to a stop let's i'm doing 25 foot off the gas coasting to a sop it starts to sure a little bit. then when i'm at a stop just sittin still it surges feels like it's gonna die then jumps back up a little bit. and in nuetral it does the same thing it feels like it's gonna die then jumps back up and occasionally in drive or nuetral it will die every once in a while.
basically it idles like ****.
please any help at all whatsoever suggestions or anything you have please help me
Old Jul 20, 2008 | 03:08 PM
KITTvsKARR's Avatar
Car: 02 WS6, 83 WS6, and 78 Project
Engine: LS1, LG4, and 400
Transmission: 4L60E, T5, and TH400
Axle/Gears: 3.73, 3.73, and 2.73
Re: Annoying Idle problems
I have the EXACT same prob with my 85.. had a shop try to figure it out (charging me 1200) and said they couldn't figure it out... pisses me off... But same thing.. when you are on the gas.. no prob.. if you hold the gas just a tad at a stop while holding the brakes.. its fine.. but like you said.. coasting.. or sitting longer than like 30 secs.. and it surges BADLY.. tries to shoot forward.. then eventually dies...
Old Jul 20, 2008 | 04:10 PM
RyanWilson's Avatar
Car: 1989 Camaro IROC-Z
Transmission: 4-SPD Auto.
Ha lol Currently having a similar problem with my 89 Iroc... Sitting idling or slowing to a stop will just die out lol.. i have been working on this for two months now lol i will post this solution as so as i have found it and i will hopefully still have some hair left at that time too
Old Jul 20, 2008 | 04:16 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Having a very similar problem with my BRAND NEW (25 miles) 355 TPI. I'd love to have some input on this as well.
Old Jul 20, 2008 | 04:18 PM
KITTvsKARR's Avatar
I've been told the throttle cable could be an issue.. if its sticking... I haven't gotten in there to check it out...
Old Jul 20, 2008 | 05:01 PM
IROCthings's Avatar
Axle/Gears: 3:73
i've heard a few different things, one being it could be the i air control it could just plainly be dirty, two it could be the timing, three it could be the throttle position sensor. i know there are many more theories and or soloutions and i would die to hear them.
Old Jul 20, 2008 | 05:11 PM
KITTvsKARR's Avatar
Replaced my IAC twice.. and the TPS once.. took apart and fully cleaned the intake twice... not sure about the timing.. but Its gotten me COMPLETELY frusterated.
Old Jul 20, 2008 | 06:51 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Ill join the club with idling and surging problems with my modded 355 tpi setup.But I figured out many things about fixing these issues and I will say check everything..dont assume things are right just because you put on new part.If you installed a new tps or iac..double tripple check that they are set correctly and then relearn the computer.Check fuel pressure,timing,esc module,02 sensor,coolant temp sensor,mat sensor,Vacuum leaks etc.I made a list based of searching the boards of other peoples experiences and learned so much about what to look for and then I attacked my car with a plan and bit by bit it went away.I couldnt tell you exactly which part may have caused it..Id say its just a mixture of everything not being happily in sync and throws it off.And guys..dont get too frustrated..i lost my cool at first and wanted to just burn the damn thing up lol..keep a very open mind that the smallest thing can be the biggest problem and you might just laugh at what is causing your poor idling and drivability.
Old Jul 20, 2008 | 08:25 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
move the mafs connector around
those terminals inside tend to get a little spread out
Old Jul 20, 2008 | 08:44 PM
IROCthings's Avatar
Axle/Gears: 3:73
ya know, my friend's uncle said that i need to get a new ignition control sensor would that effect anything?
Old Jul 20, 2008 | 09:33 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Yes that module can cause bad idle at times.I did a code every now and then for esc.When i did get around to checking it,I had found it was old and had poor contact patch.Got a new one and that solved that problem.
Old Jul 20, 2008 | 10:51 PM
IROCthings's Avatar
Axle/Gears: 3:73
how much did it cost you to replace that module?
i think the idling thread for tune ports should be a stick in all reality.
Old Jul 20, 2008 | 10:58 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
My surging problem was a bad EGR valve , it cleared right up when I replaced it .
Old Jul 20, 2008 | 11:07 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
The esc module on the dist was cheap..about $20 if memory serves me correctly.I dont have any emissions/smog on my car so it forced me to cover the basics of what would cause my problems.
Old Jul 20, 2008 | 11:37 PM
IROCthings's Avatar
Axle/Gears: 3:73
Does anybody know what all goes into removing your smog pump so i can get rid of my egr valve. cause well i have no egr tube at all. it pretty much cuts off at the egr valve.
Old Jul 21, 2008 | 05:25 PM
IROCthings's Avatar
Axle/Gears: 3:73
so today i drive my car twice, it's still doing the idling thing but i can deal with that, but the second time i start my car,it does this wierd thing. i step on the gas and it just idk it feels like it gets no gas it spits n sputters and idk how to describe it i took it up the street into a parking lot to give it some gas still does it then i make it about another half mile and it stops doing it. it felt just dirty. any ideas?
Old Jul 23, 2008 | 06:37 PM
522viper's Avatar
My 88 Trans am did the same thing. At first I thought it was the Fuel pump, but it really was that the distributor was very dirty. So, I took it out cleaned everything and placed it back, so far it works great!
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
db057
Aug 22, 2015 08:17 PM
