Fuel Getting into the Oil
Old Jul 24, 2008 | 04:11 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
I opened up the tube that connects to the side of the air intake that leads to the valve cover on the passenger side, smelled like fuel. Took the oil stick out and smelled it, and yep, smelled like fuel. whats the cause of this???
Old Jul 24, 2008 | 05:13 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Fuel Getting into the Oil
most of the time, it's the piston rings.
Old Jul 24, 2008 | 07:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I would lean more towards a sticky injector.
Most of the time bad rings cause oil burning.
Old Jul 28, 2008 | 02:42 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
I know how to get to the injectors and what they are, but what do you mean by sticky and how do I fix this problem?
Old Jul 29, 2008 | 04:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The pintle gets gunk buildup.
You can try Techron fuel system cleaner or you could pull them all out and send them out to get cleaned.
Old Jul 29, 2008 | 08:06 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
do i need to put the fuel system cleaner directly into the fuel rails to get directly on the injectors? where is the entrance in which I put in the cleaner, because Im not positive of the best way. after its in there, do i need to turn the key or anything else i need to do?
Old Jul 29, 2008 | 02:43 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
dump it in your gas tank.
Old Jul 29, 2008 | 06:05 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
well is this sticky problem the cause of overheating too? I will go on and give it a try but the car barely starts and i have a full tank so im not sure putting it in the tank will do much good
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
