pick me a cam [vortec tpi 355]
Old Jul 28, 2008 | 10:31 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello...
heres my specs....
355 roller flat top pistons 9.5:1 compression ratio
062 vortec heads non ported
fully siamesed slp runners, ported SDPC manifold, siamesed plenum,
268xfi comp cams cam with 1.6 rockers
full exhaust
i made267 hp at the wheels and 275 torque [wheels]
the dyno pull results can be seen on this thread.. sorry for the inconveinience..
https://www.thirdgen.org/forums/tpi/...tec-355-a.html
my valve springs were binding up and it one of th possible reasons to my low numbers.. many people have pitched in to say the cam isnt right for the vortecs.
the specs on the cam are 113 lobe separation 218 224 duration 570 565 lift.
yes i had the vortecs machined for the lift, but the wrong springs were installed by my engine shop FYI
ive heard the vortecs dont like that kind of lift... it should be low 5s?
thanks
Lee
sorry i forgot to specify, this car is a daily during the summer and need to be reliable.. but i do want to take it to the track.. so dont go crazy on duration becuase its a pain to tune and doesnt run well.
Last edited by speedmachine; Jul 28, 2008 at 10:33 AM. Reason: Automerged Doublepost
Old Jul 28, 2008 | 12:18 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: pick me a cam [vortec tpi 355]
Unless you suspect that you hurt the cam or lifters, I'd just get a set of 1.5 rockers and the right springs and be on my way.
If there is other damage, I'd go with the comp XR269HR12.
Old Jul 28, 2008 | 12:35 PM
86 IROC's Avatar
Depends on what you want... track car, daily driver, weekend car/ocassional track car?
I'd say something like a ZZ4, ZZ9, LT4 hot cam, etc.
Old Jul 28, 2008 | 01:40 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
The goal is to make as much power as possible without turning into an overheating, non idling, track only machine. Not shy by any means we are looking t push this thing as far as it can go as #1 priority and I too think we should just bang on the 1.5's, fresh springs and give er a shot but we were hoping for some Vortec cam specific input and hoped that we may find someone who has tried a few combos and has the magic stick
Old Jul 28, 2008 | 02:14 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
I think you already have the magic stick for that intake/head combo.
Old Jul 28, 2008 | 02:27 PM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
I have a question, I see you have a vortec engine. I have a 1999 vortec 350 engine with the heads, can I use my 350 TPI setup on that engine?
Old Jul 28, 2008 | 05:24 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
are those Vortecs stock? if so, that way too much lift at the valve. they only like around .470"
Old Jul 28, 2008 | 05:54 PM
Car: 1989 IROC-Z
Engine: 346 LS6
the manifold bolt patern is different to run tpi on vortecs you need the SDPC manifold.
the heads are machined for the lift on the cam[.570 .565]
what ive heard is that past around .530 lift the swirl effect of the air entering the port stalls ruining their fast burn effect.
Old Aug 7, 2008 | 04:31 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I put a stock LT1 cam in a motor for my sons 72 chevelle - vortec heads added rollers to a 87 and later rebuilt shortblock idles like kitten and pulls like a LT1. it is a SLEEPER! the lift is fine with the vortecs q-jet, small tube headers - it was a great idea except the LT1 has no lobe for the fuel pump
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
