Any one running 30lb injectors
Old Aug 5, 2008 | 06:39 PM
89jim's Avatar
I was wondering if anyone out there is running 30lb injectors? I have a 383 with ZZ4 cam,SLP runners,SLP headers 1 3/4, SLP cold air intake,52 MM throttle body,air foil,3" hooker cat back, 89 corvette heads reworked.
If so what has to be done to run them?
Old Aug 5, 2008 | 08:53 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Any one running 30lb injectors
I have a set of 30 lbs accel injectors. I know they are not the best but they can supply a constant 48 psi throughout the powerband
Old Aug 5, 2008 | 08:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes and you will need a custom tune.
Old Aug 5, 2008 | 09:16 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
I run them on a 406, ford 30lbs
Old Aug 5, 2008 | 10:18 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am running 33 lb injectors.
I am using the super aujp.
Results in the sig.
Old Aug 6, 2008 | 12:27 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i run 30ib injectors too but you just have to adjust the tune for them.
Old Aug 8, 2008 | 07:33 AM
89jim's Avatar
Well thats good to know.I put a set in but the car does not run right.I did have a chip burned for them and that my be the problem.The guy who burned it burnt my last chip and the car ran great.He is going to make another one and see if it is better. I can not keep the car running less than 2500rpm and get a back fire up the tune port once in a while. I pulled a few plugs and they are black and damp. The plugs are brand new. I ran the car maybe 3 minutes total time so far. I have 45lbs at the fuel rail and a new high volume pump in the tank.
Old Aug 8, 2008 | 09:28 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Your in the right section, why don't you
learn to do it your self
Steve78LT
Feb 24, 2016 12:15 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
