code 42 problem
Old Aug 2, 2008 | 05:15 AM
snowmad's Avatar
Car: 89iroc-z 97-firebird
code 42 problem
hi!
my -89 L98 shows a code 42 that can't be erased (the promlem not found or solwed...)
It runs, but timing can't be as it's suposed to.
It makes a "ping'ing" sound just by flicking the trottle.
when checking the timimng at idle with "the cable" disconected, timing is right at the spot.
The problem came from nowere, after just standing still a cup of coffe (30-45 min) (key off)
anyone had this problem?
Old Aug 2, 2008 | 09:33 AM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
Re: code 42 problem
The code is indicating a problem with the Electronic Spark Control Module. Runs around $70 bucks. As for why it died, everything dies eventually. Yours just decided to give up the ghost while you were getting coffee.
Old Aug 2, 2008 | 03:58 PM
snowmad's Avatar
Re: code 42 problem
...so you mean it's dead but it dosn't understand it yet?
engine still runing but with the ping problem?
the Spark Control Module, is it flat and located unther the dist cap?
with 2 conectors from the outside and one inside?
Old Aug 2, 2008 | 07:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: code 42 problem
No, that's the ignition control module. The Electronic Spark Control Module is next to the winshield wiper motor. The ESC uses the the signal from the Knock Sensor to retard timing.
Old Aug 19, 2008 | 04:41 PM
snowmad's Avatar
Re: code 42 problem
i changed to a new "esc" it's still knocking = no better...
what if the Knock Sensor is bad, (it has seen a lot of heat due to the headders) vill that set the code42 and make it start ping/knock?
Old Aug 20, 2008 | 02:37 PM
snowmad's Avatar
Re: code 42 problem
any one got a advice to give ???
Old Nov 21, 2008 | 03:18 PM
bigals87z28's Avatar
Car: Check The Sig
Re: code 42 problem
ESC is code 43, not 42.
Im having the same problem no, but it jumps back and forth.
I will be driving along no problem. Then out of no where, it will start to spit and spudder out. It will stall, come back alive, stall again. Sometimes it comes back to life and just shoots an engine code to where I just go to limp home mode. I turned it off, sat for 5 mins, started back up and no problem!
Never had this problem before, but before the SES light shot on right as I started the car, that was a code 43.
Im gunna replace the Ign control module, the one under the dizzy.
Old Nov 21, 2008 | 05:44 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: code 42 problem
Here is a chart for the code 42. Should get you going in the right direction.
Old Nov 22, 2008 | 09:51 AM
Car: Check The Sig
Re: code 42 problem
Replaced, and all is well.
Old Nov 22, 2008 | 11:14 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
Re: code 42 problem
Interesting! I have a 305 TPI that I've been trying to get to run smoot with ALDL (ECM) pins A & B jumpered (Service Mode). My symptoms are exactly the same as you describe. it will run for a bit during acceleration, than BAM!, it will jerk and sputter. I have a new ignition module, I think I'll put it in. Have you also replaced the Pick-up Coil? My ignition module and pick-up coil are in the distributor. are yours?
Old Dec 10, 2008 | 05:28 PM
Car: Check The Sig
Re: code 42 problem
Yes, I have the small cap HEI as should you. This distributor is actualy one I picked up from a friend, and sent it to the guy finishing my car.
I would replace the ignition modual and see what that does, sounds like you have the same problem as I did.
Old Dec 15, 2008 | 05:09 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: code 42 problem
had a friend with this issue. We replaced the distributor because the wires on the inside of the distributor were corroded going to the ignition module. Fixed it right up and no problem since.
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
