check this out....do you think it will work?
Old Aug 13, 2008 | 01:15 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
so im putting in an 89 TPI 350 into my 91 RS. i need a MAF sensor and i ran into this
http://sandiego.craigslist.org/nsd/pts/790012390.html
wil this work on my TPI? it about all i need for it to be complete.
im new to TPI so im not to sure about the induction...
thanks TPI guys
Old Aug 13, 2008 | 01:49 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Re: check this out....do you think it will work?
he is wrong on the year, 84's were all carbed
Old Aug 13, 2008 | 02:02 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
well i guess he's an idiot then. ill ask him to double check.
but i wanted to know that regardless of the right year, will it work on my 89 TPI? does different years make a difference at all??
Old Aug 13, 2008 | 03:49 PM
Car: IROC Z
Engine: 5.7
not sure on that one see if theres any numbers on the part sticker that he can give you to identify it
Old Aug 13, 2008 | 03:56 PM
Stephen's Avatar
Car: 87 GTA
It could well be out of a 84....Who says the engine wasn't swapped in by a previous owner?
But yes...Any early F-body MAF will work. Obviously, you'll need a TPI ECM & a lot of rewiring to switch to TPI, but it's just a matter of work.
Old Aug 13, 2008 | 10:23 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
yes, the year isnt important right now, its a MAF sensor for the TPI. like i stated before, i have EVERYTHING for this swap but when he gave me the intake, it was just the intake hose and no MAF/SPEED DEN for it, so that all i need. if you say it will work then ill just buy it off of him instead of paying the 200 off tpiparts.net
thanks guys
Old Aug 14, 2008 | 11:15 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just remember...if you put a MAF system on a '91 in Ca. the only way to get it smogged will to pay someone under the table.
Old Aug 14, 2008 | 11:45 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
thats true and thanks for the heads up, but this might just be temporary till i go speed density. i just need to know what all i need to switch to speed density. thanks don
Old Aug 15, 2008 | 07:42 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
85 will be different
Old Aug 15, 2008 | 11:26 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
who said anything about an 85....im confused now
Old Aug 15, 2008 | 12:16 PM
Car: IROC Z
Engine: 5.7
you're 85
Old Aug 15, 2008 | 01:27 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
there are only 2 different MAF's for these cars . 1 is for the v6 (MPFI)cars and 1 is for the v8 (TPI) , the year does not matter . the one in the pic is for a v8 (TPI) and looks like 1 of the screens are removed .
for $50 you would be better off getting 1 from a member on here that can verify it is good because these are known to go bad and there is no way to test them other than on a good running motor .
Old Aug 15, 2008 | 01:31 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
cool, that pretty much sums up my question of "will this work on my 350, since his is a 305"
so any V8 maf sensor works good? ill ask him what condition its in, i dunno i havent came across anyone here thats selling a MAF sensor.
he said he's getting rid of it because hes switching to MAP...whatever that is. speed density??
you're 85
i dont have an 85.....the engine swap im doing is an 89 into a 91...
Last edited by samiam91RS; Aug 15, 2008 at 01:32 PM. Reason: Automerged Doublepost
Old Aug 15, 2008 | 01:39 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
yes , the MAF from all tpi cars are the same . trans am , camaro , corvette , 305/350 ect ...
Old Aug 15, 2008 | 01:56 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Here are some of the part numbers for oem, new, and remanufactures.
Feel free to add/correct to this list.
Read past posts about the differences
File Type: doc
Old Aug 15, 2008 | 02:03 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Old Mafs read lower than new ones at the same air flow, so will run leaner.
These guys will test and return, $70 to repair.
SIA Electronics
730 N. Minnie St.
Tilden, IL 62292
800 737 0915
Old Aug 15, 2008 | 02:41 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
there i fixed it just for you ..
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
why do not you convert your tbi harness to SD?
https://www.thirdgen.org/forums/tpi/...d-density.html
Old Aug 16, 2008 | 06:36 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
im done with the TBI, im swapping to 350 TPI the whole engine, the whole induction set up, and just needed info and what not on the MAF. thanks for the info guys and i really appreciate it about the rebuild address...
i talked to the guy, he said he swapped the motors a long time ago and this MAF sensor has been sitting around for almost 10 years
not being used. hes cool, and wants to make sure it will work and what not, he said even if it didnt he's consider exchanging it back with me. but im sure ill be pleased.
thanks again guys
Old Aug 19, 2008 | 02:22 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
alright! so i picked it up yesterday and its all good. everything seems fine (i know you cant go off of looks for a MAF sensor) but hey, ill give it a shot. from the numbers that were provided it came off an 86/87 so thats cool.
the guy said its been sitting around for the last 10 years in is garage which could be good, that most likely means it has low miles of usage. i saw the 350 TPI that he as now inside a 55 ford. pretty sweet! he converted it to speed den so he didnt need it anymore, which was a long *** time ago but its cool. probably the best 40 bucks ive spent.
Old Aug 20, 2008 | 12:13 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Depending on the mods to the motor and the screen removed you might have to reprogram the eprom. The more changes, the more likely the tune will be off.
88I_R_O_C_ZTPI
Thanks for the fix, but I already have a "Blonde DD".
Old Aug 20, 2008 | 09:44 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
hmm i dint think that the screen will make a difference at all. all that matters in a MAF sensor are those wires runnin across and theyre all intact. but thanks for the heads up
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
