fuel pump problem
Old Aug 23, 2008 | 06:11 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
fuel pump problem
so i go to change my fuel pump and well honestly it seems like more of a hastle to drop that stupidly shaped fuel tank than to use an air hammer to cut a hole in the trunk.
so unless somebody can explain to me the correct procedure for dropping it out from the bottom of the car....
then please show me where i should cut this hole out.
becasue honestly having to deal with the fuel lines and getting everything back in correctly it seems a little more difficult.
call me dumb whatever idc i'm just tryin to get this all sorted out please.
Old Aug 23, 2008 | 07:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: fuel pump problem
Cutting a hole in your car and hacking through 4 fuel lines is just not the right way to go. It's not safe to patch the lines with rubber hoses either. It's a pain, but it's worth doing right (or paying someone else to).
Old Aug 23, 2008 | 07:51 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
read through this thread and you will have everything you need to know about cutting a access panel .
on the last page i posted a pic with exact measurements on where to make the cut .
https://www.thirdgen.org/forums/tpi/...cces-done.html
Old Aug 23, 2008 | 08:09 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
to drop the tank ,
get the car as high up as you can safely .
drain the fuel
disconnect the fuel lines , pump harness , filler neck , rear brake lines , ebrake cables , sway bar , drive shaft , shocks .
drop the rear end
let the exhaust hang down
unbolt the tank straps and drop the tank
remove the sending unit .
separate pump from sending unit .
do the reverse .
im sure i forgot some small detail but that is the jist of it .
Old Aug 24, 2008 | 12:31 AM
IROCthings's Avatar
Axle/Gears: 3:73
from what i'm hearing from the fbody guys i know you don't need to cut any lines whatsoever. so is that the case here is there a way to avoid it or what. cause i need to do this like tomorrow. done and over with.
Old Aug 24, 2008 | 03:19 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
here you go I've done it at least 10 times:
jack rear as high as you can go then support on jack stands,remove rear tires,panhard bar,track bar and sheilds below gas tank.unbolt rear sway bar in pass tire well.Unbolt pass side rear LCA bolt.unbolt shocks,Pass spring should fall out,remove gas door & black inner thing.Disconnect gas lines be sure to use backup wrench,Disconnect electrical connector above gas tank.Unbolt exhaust at converter and take out pass side of car.Unbolt straps holding tank and slowly manuver down and out.Tank will rest on lowered rear and you willbe able to remove ring on top with hammer and screwdriver.
Old Aug 24, 2008 | 12:48 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
I just replaced mine for the first time and I did it the right way. NO hacking here!! It was alot easier than I thought!!!! Don't hack it it.
Old Aug 24, 2008 | 01:35 PM
IROCthings's Avatar
Axle/Gears: 3:73
Originally Posted by NY87Iroc
I just replaced mine for the first time and I did it the right way. NO hacking here!! It was alot easier that I thought!!!! Don't hack it it.
all the unbolting of **** doesn't sound to easy.
i'm not gonna lie you on a foxbody it's pretty simple
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
