Stroking my 305
Old Sep 4, 2008 | 01:31 PM
screamingpete87's Avatar
Stroking my 305
I want to keep my car original. However, I want to maximize my CID. I want to put .060 flat top pistons. I want to know if I can put a 3.75 stroke crankshaft in my cute 305? Basically I am doing the same thing that would create a 383 with a 350. Am I going to have any clearance problems? This should bring my CID up to 338. Can I have some input. Please do not tell me just to put a 350 in my car. I want to keep my 305 numbers matching z28. Thanks for the help.
Old Sep 4, 2008 | 01:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stroking my 305
You can, with the same sorts of clearance problems you'd find in a 383, only more.
Old Sep 4, 2008 | 02:31 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Stroking my 305
boring and strokeing the 305 like that will not make a 383 it will make a 339.5185782498745 cubic inch motor....i know its not what you want to hear but it would be cheaper and easier just to jump to a 350...more displacement. plus if u put in a 350 it still apears stock there are so many people in this world that claim they have a 350 when they only have a 305 u could be the oposite lol if you want to keep in numbers matching thats cool i guess but thats the info...i couldnt see spending all that money to still be smaller then a stock 350 but we will help ya when u need it....good luck and welcome to TGO...
Old Sep 4, 2008 | 02:38 PM
Guest
Guest
Posts: n/a
Re: Stroking my 305
Kind of a waste, but... do yourself a favor. If you plan on doing this to keep your 'numbers matching' block, dont bore it .060. Bore it as little as possible to get the cylinders round. Anything more is a waste and if you ever have to rebuild it again there's material there to bore again.
Old Sep 4, 2008 | 03:12 PM
10secondhopeful's Avatar
Car: '84 Z28
Re: Stroking my 305
dang, i havn't heard of too many people boring and stroking a 305, and i know that its definatly not what you want to hear, but the guys above do make sense. you would still have a engine with a smaller ci than a stock 350. not to mention gets parts for a 336-339ci engine about be a pain n the ***. a 350 drop would be the best but if you don't want to do that, i would recommend just getting a bigger intake manifold and doing some extensive head work. thats just my
Old Sep 4, 2008 | 03:15 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: Stroking my 305
umm no small block parts are pretty muchs small block parts no harder finding parts for a stroked out 305 then it is to find parts for a 350.....
Old Sep 4, 2008 | 04:12 PM
Car: '84 Z28
Re: Stroking my 305
we had a harder time trying to find parts for my friends 327ci then we did for a 383 stroker, just saying from personal experience, we might have been looking in the wrong places but idk
Old Sep 4, 2008 | 04:15 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: Stroking my 305
care to elaborate because aside from the rotating assembly anything else on a 383 should bolt right up to a 327....
my bad to the main poster looking back i see you wrot 338 on what your cid will be i swear i saw 383 lol well after all u just swap the places of the last two numbers to get it. but aside from that the rest of my statement holds true sorry...
Last edited by igotta355z28; Sep 4, 2008 at 04:18 PM. Reason: Automerged Doublepost
Old Sep 4, 2008 | 05:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Stroking my 305
The rotating assembly parts for a 335 are much less common than for other combinations, which means there's much less selection, and higher prices to be paid.
Old Sep 4, 2008 | 07:15 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Stroking my 305
The difference is in the balance of the rotating assy, the smaller pistons weigh less so the high speed balance will be harder to get.
The other difference will be the tune, there are lots of stock 305/350 chips to pick from, the 335 will be between them.
Old Sep 4, 2008 | 09:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Stroking my 305
Pistons for a 335 aren't much lighter than pistons for a 305, which aren't that much lighter than pistons for a larger bore SBC. There's no difference or additional difficulty in the balancing process.
Old Sep 4, 2008 | 09:33 PM
Re: Stroking my 305
Thanks for all the input. I have a high output 305 so by changing the crank and keeping the flat top pistons with keeping the stock head, am I going to run into valve clearance issues and how much is my compression going to increase? Keep in mind that I am going to be doing minor head work that will include a parrallel decking.
Old Sep 4, 2008 | 09:43 PM
Guest
Guest
Posts: n/a
Re: Stroking my 305
You need a book on engines.
You cant use your current pistons. If you use the correct ones, compression is determined by what you pick, and valve clearance is determined by the camshaft.
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: Stroking my 305
hmm so why do u want to keep the camaro numbers matching? if its for a value later on wouldnt it be better to have the motor as close to stock as possible? if this is your reason have u ever thouhgt about just pulling the motor and storing it and replacing it with a better larger cid sbc? just keep all your stock stuff so u could change back later. if this isnt the reason for keeping it numbers matching i just cant forsee any other reason actually. because unless some one is going to crawl up in your engnie bay with a flashlight and try to read the block numbers wich ive never been able to read with a motor installed...there is no way they can tell your lets just say 383, is not a 305...
Old Sep 4, 2008 | 09:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Stroking my 305
You don't parallel deck heads, you parallel deck blocks, but that would obliterate the stampings you need to stay numbers matching.
You can with a 5.565" rod, as long as the block isn't bored.
Old Sep 4, 2008 | 10:06 PM
Guest
Guest
Posts: n/a
Re: Stroking my 305
Well yeah... I guess so.
Anyway. back to your regularily scheduled post.
Old Sep 4, 2008 | 10:07 PM
1989irocz1's Avatar
Car: 1989 Camaro Iroc Z28
Axle/Gears: Borg Warner 9-Bolt/ 2.77
Re: Stroking my 305
That is probably the best idea, pull and store the motor. Then put a 350 in.
Old Sep 4, 2008 | 10:40 PM
Re: Stroking my 305
I dont want to do a 350. I want to rebuild the 305. I want to stay off the beating path and at the same time keep the car original.
Thanks for the book tip. LOL
Last edited by screamingpete87; Sep 4, 2008 at 10:41 PM. Reason: Automerged Doublepost
Old Sep 5, 2008 | 11:59 AM
Car: '84 Z28
Re: Stroking my 305
Okay turns out my friend is just plain stupid and doesn't know much about small block, sorry for confusing you man
Old Sep 5, 2008 | 12:00 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: Stroking my 305
its all good
Old Sep 5, 2008 | 12:02 PM
Car: '84 Z28
Re: Stroking my 305
dang pete your sure set on keeping the car original. well these guys have some good ideas so just go along with that
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
