91 5.7L TPI, timing specs?
Old Sep 9, 2008 | 07:12 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
what are the stock timing specs for this car.. the decal is long gone and I can't seem to find it in my shop manual. if I recall it was 6deg btdc for my 5.0L TPI iroc, is it the same for the 5.7?
I'm trying to get a bit more power out of this car, today I check the fuel pressure and found it is good at 44psi, and the timing is set to 0.
Old Sep 9, 2008 | 07:54 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 91 5.7L TPI, timing specs?
I believe the timing specs from 305 and 350 are the same on tpi cars.
Old Sep 9, 2008 | 09:14 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Funny I just did the same on mine. Owned it for 4 years now, and done a bunch of work but never checked the timing. Doh! Mine was at 1*
Stock for the L98s is the same as the 305, 6*
I'm headed to the track tomorrow night.. lol maybe I'll pick up an extra tenth
Old Sep 10, 2008 | 03:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Vote #3 for TPI being 6 btdc.
I believe the TBI's were 0.
Old Sep 10, 2008 | 08:36 AM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Old Sep 10, 2008 | 08:47 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
The 6* BTDC contestants win the round!
Bill
Old Sep 10, 2008 | 10:39 AM
Brisk's Avatar
thanks guys
Old Nov 11, 2010 | 05:57 PM
diehard92's Avatar
Car: 90 Iroc-z tune port 350 mod
Engine: TPI 350 chipedout neck breaker tran
Transmission: 700R4 built
Axle/Gears: 7.5 10 bolt rear end
here is a little infor for you guys its at 6 but if you want to get just a little more power out of you time and valve tran you can more it up to about 8 or 9 and you will see a big difference
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
