coil voltage
Old Sep 13, 2008 | 09:33 PM
82camaroWI's Avatar
coil voltage
anyone know the voltage on a stock coil for an 83 camaro 2.8l v6?
Old Sep 13, 2008 | 10:16 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: coil voltage
prob in the 30,000-36,000 range. aftermarket for V8 like MSD blaster is 48,000. accel is bout the same, hypertech has a 52,000V. i would think the stock v6 would be the same as the stock v8.
Old Sep 14, 2008 | 01:05 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: coil voltage
Stock HEI is ~38,000 volts, I would imagine the v6 coil would be somewhere in the same neighborhood.
Old Sep 14, 2008 | 05:47 AM
82camaroWI's Avatar
Re: coil voltage
well i just bought a high performance 60,000 watt coil for 40 some bucks off jcw it was on sail, but i think its a generic brand, still it should run really good and i got new points
Old Sep 15, 2008 | 08:04 PM
Car: 87 TA clone
Re: coil voltage
i really doubt its 60,000V... i dont beleive anything the JCW says... i would think its prob in the 40,000's range. still it will run good. it runs fine with the stocker.
most of the aftermarkets dont go above 50,000. 52,000 being the most ive seen. i dont even think that the MSD boxes etc go up to 60,000V
Old Sep 15, 2008 | 08:13 PM
82camaroWI's Avatar
Re: coil voltage
this is the coil i bought
http://www.jcwhitney.com/autoparts/P...+60%2C000-VOLT
Old Sep 17, 2008 | 12:41 PM
Car: 87 TA clone
Re: coil voltage
yea i dont believe it sry, looks too cheap. why a 60,000 from JCW when others like MSD, mallory, pertronix, accel etc dont run that high and there prices are more steep... i kno its all bout the name but still id be weary... still tho ur engine should run fine if not better with it.
Old Sep 17, 2008 | 02:56 PM
82camaroWI's Avatar
Re: coil voltage
i usually try not to buy for the name, 90% of the time it doesnt make a difference
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
MM2Robinson
Oct 1, 2017 09:16 AM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
