Rear-main bearing
Old Nov 8, 2008 | 10:49 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
Rear-main bearing
Okay well I am pretty sure my rear main bearing is going bad. I just want to know how hard it is to do? and do you have to pull the engine? also anything else I should check since it is going bad?
thanks
Old Nov 8, 2008 | 11:16 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: Rear-main bearing
i dont think your gonna have to pull the engine but i know the transmission will have to come out along with the driveshaft so you can pull the flywheel/flexplate off and drop the crankshaft out after pulling the oil pan, also while doing this you may want to go ahead and replace the rear main seal it will save you quite a bit of trouble later especially if its the one piece style, i dont know how much clearance is between the steering and the oil pan on these cars but some you can pull the pan right out.
Old Nov 9, 2008 | 12:57 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
okay thanks for the info, I dont have the ability to do it myself just wanted a heads up for when I have to talk to mechanics.
Old Nov 9, 2008 | 01:25 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm just curious: Why do you think the rear main bearing is going?
Old Nov 9, 2008 | 09:58 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It will be easier in the long run to pull the engine. There's really not enough room to pull the crank in the car. This is something that needs to be done carefully and kept clean.
Old Nov 9, 2008 | 03:56 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Old Nov 9, 2008 | 04:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Originally Posted by Frank 84 Bird
Old Nov 9, 2008 | 09:48 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
Originally Posted by UNCLE TOM
hmmmmm well the knocking sound is the first giveaway
but no I have some mechanical exp. and I was at a car meet the other night and asked some other opinions and they agreed with me on the bearing, plus it knocks harder in drive then in park, so once its puts a load on the engine the stress makes it knock harder which should be the main bearing(and its the rear main bearing cause it knocks in the rear not the front)
I agreed completely just wonder how it could be done, but I cant do it so its up to the mechanics
Old Nov 9, 2008 | 10:11 PM
jv9999's Avatar
Engine: 5.7L/350
Now is a good time to consider another engine. New or a known good used one. Once you start paying the labor and machine shop costs, you're going to be in pretty deep anyway.
Old Nov 9, 2008 | 10:32 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
well the engine couldnt run better as it is, I just want to get it fixed before it wont run. I shouldnt go buy a new engine just because its a knock. its been doing just fine for 2kmi so I dont think I want to go that route. also its not a motor that comes with the car, mine is an 85 and the motor is an l98
Old Nov 10, 2008 | 04:25 PM
jms's Avatar
jms
I would ALMOST bet a penny that it is a cracked flexplate. From my experience with small block Chevys, rear main bearings just don't go bad before the front main.
The rear main gets oiled first while the front gets oiled last.
Drop the converter cover and take a close look at the flexplate. Often from one of the big round holes toward a converter bolt hole.
I've had cracked flex plates that sound just as you describe.
jms
Old Nov 10, 2008 | 10:42 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
[quote=jms;3944539]I would ALMOST bet a penny that it is a cracked flexplate. From my experience with small block Chevys, rear main bearings just don't go bad before the front main.
jms[/quote
well i took it to a shop today they said bad rod bearing and it sounds like the cylinder might be tapping the head
Old Nov 10, 2008 | 11:56 PM
jms's Avatar
jms
Rear main bearing going out, by itself, is somewhat rare. Rod bearing going bad is not as rare.
Hope everything works out for you.
jms
Old Nov 11, 2008 | 12:59 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
jms
yeah now I gotta find the few thousand it will cost to have it fixed or replaced
fun
Old Nov 14, 2008 | 09:07 PM
the blur's Avatar
either way the motor is garbage.
and I highly doubt it's the rear main.
but even if it is a rod bearing, replacing a bearing is a waste of time and motor.
start yanking.
Old Nov 14, 2008 | 10:32 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
start yanking.
Why would it be a waste to spend 50bucks and fix something then spend a couple grand and get a whole new engine? ether way, its worth the time if you dont have the few thousand to spend on everything else. and this will help me save money so I can get rid of this "garbage motor" as you say.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
