pros and cons of a 383 tpi
Old Dec 23, 2008 | 11:05 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
basically what the title says also how difficult would it be to put in a 383 kit yourself with a pretty good knowledge of the car a a fairly good tool set thinking of doing it over the winter but no sure yet thanks for any help
Old Dec 23, 2008 | 11:52 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: pros and cons of a 383 tpi
Mechanically there's no difference in building a 350, or 383.
You relly need to decide on what you want; daily driver, street/strip, Race only...etc. Mine is for daily driving, and mild street as such it had to have all green stuff working.
Buy the parts take them & block to a shop to do the machining & prepping then put it together yourself. Ask about issues like clearance issues from using a longer stroke.
Use a performance shop, but don't let them dictate on what combination to use. Ask for advice, but remember that's all it is advice you don't have to agrre with it. Have a cam company recommend a cam based on what you decided on the use of the car will be.
And we are here to help. Happy wrenching!
Old Dec 23, 2008 | 11:56 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
looking to build a daily driver that i can also race on weekends at the track
and how much does a machine shop usally cost
and also which kit is the best qualtiy and doesnt have to be the cheapest
Old Dec 24, 2008 | 09:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Every time I asked how much to my machinist he said "figure everything starts at $100".
Figure all machining between 300 and 800 bucks. Depends on what you have done.
I like my Eagle crank and rods with SRP slugs. $1800 for the forged kit.
Old Dec 24, 2008 | 10:16 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Just remember that the estimate they give you is an estimate. Everytime I've had work done it came to $100-$200 more than originally thought.
Old Dec 24, 2008 | 10:41 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Give R&E Racing in Lancaster a call, talk to Ed in the shop.
Old Dec 24, 2008 | 12:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
by the time your done a crate motor would be less even with quality parts, but if getting your hands greasy is what makes you happy go for it, I did.
Old Dec 26, 2008 | 03:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
With a long-runner TPI intake, forget it. You'll have the same horsepower as a 350, but so much torque the car will be hard to control when launching. And you'll go thru rear tires like they were free.
Save yourself the extra cost and build a 350. See my posts in the TPI board on "Our quest for a better flowing TPI" and "Visual TPI intake ports" to see the reason why a long runner TPI doesnt work with a 383. Those posts will also tell you what you have to do to a TPI intake to make it work above 4500 rpms.
And when you're done with your engine, call me up and I'll do the custom chip for you.
R & E Racing is a good place, I usually talk to John when he buys parts from me at Manley.
Old Dec 27, 2008 | 04:02 AM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I think, decide what kinds of cars you want to beat. A stock car is fine for racing at the track. Do your bracket well.
If you want to beat a completly stock LS1, you can easily with 350 mods, but look very carefully at what others have done before.
A 383 may resemble stock, but what you might need to feed it may not pass CA smog. (I don't think a 700r4 could handle it, either.) There are 3rd gens in CA faster than 11 sec, but maybe not smog legal.
The more torque and Hp you make, the less "daily" it is, you have to make sacrifices in one place or another, esp. handling.
I don't care how easy it sounds. This is why exotic cars cost so much. But if you like it, its worth it.
It is easier to adjust to small changes in your cars mods, a race car can be a beast. /\
PS definitly go for forged internals. Don't forget suspension mods and body.
Old Dec 27, 2008 | 08:37 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I like my 383 Daily Driver, Rain snow ice what ever. If the car limits the torque, fix the car or get a different platform.
Drive a Hot rod on real slick roads and gain real appreciation of all that power.
Not all stock 383 TPI burn the tires off. Some just leave, read about Grumpy talking about tuning, torque, and launches.
If you want to run a "stock TPI" 383, it makes a nice street setup. My motor started out as a short block, the machine shop keeps one around for the circle track guys, all forged internals and flat top pistons. I then told the guy what I was going to do with it. He built up the rest of the engine to match the cars normal rpm range (1000-5000). He is an old carb man and didn't under stand anything computer as to cars. He knows his engines, it idles smooth and makes power where needed. Roller cam and rockers, aluminum heads.
And ask Dana at Probuilt Automatics about 383's and 700R4's, he doesn't have any problem building something that really works.
Speed is money "How fast/quick do you want to go?"
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LT1Formula
Aug 20, 2015 09:36 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
Exxon Limited
Aug 9, 2015 08:13 PM
