Grinder speed controller for grinding and porting?
Old Jan 6, 2009 | 11:18 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I want to try my hand at porting my TPI manifold but cant find a controller for my grinder that will bring the speed down to 10,000 rpms. Anyone know where I could find one? I checked Eastwood and Harbor freight with no luck Thanks!
Old Jan 7, 2009 | 07:45 PM
Engine: All 5.7's
Re: Grinder speed controller for grinding and porting?
Anybody? I know they exsist, just don't know where to buy them!
Old Jan 8, 2009 | 10:35 AM
Russ-So Cal's Avatar
Air powered die grinder or Dremel? If it is an air powered die grinder, you can get a valve to restrict airflow into the die grinder to slow it down, but it will be a "guestimate" number art best. You can get them at any place that sells air tools. What you won't find is a controller that you can take a 40,000 rpm tool and "dial in" a 10,000rpm setting. As far as I know, if you want a tool that you can dial in the rpm by using some sort of setting, it must be electric, air tools don't dial in like that. There are too many variables involved.
Old Jan 8, 2009 | 11:01 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
if you are using electrical grinder, you need a dimmer
something similar to this http://www.homedepot.com/webapp/wcs/...10000003+90047
Old Jan 8, 2009 | 01:31 PM
Engine: All 5.7's
Yes it is an electric 25,000 rpm die grinder. I plan to use a Dremel for final/delicate work but all my grinder tools say 10,000 rpm max. I bought the kit from Eastwood and the grinder from Ebay. 400zracer that looks like it should work! I'll ****** one up as I got a HD card for Christmas! Thanks all!
Old Jan 8, 2009 | 07:11 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
I bought one from harbor freight works pretty good
http://www.harborfreight.com/cpi/cta...emnumber=43060
Old Jan 8, 2009 | 07:37 PM
With electric you can control speed precisely if you can determine how fast it is running or what voltage to set for 10,000 rpm. Probably the best bet would be to install one of your high speed tools rated for the 40,000 rpm and use a digital strobe type tach. Just use a little dot of white typewriter correction fluid on the edge of the tool, and turn on the tool and adjust it with the controller. You dial in the speed you want on the tach, and then adjust the controller until the light on the tach freezes the spot in one place. Works just like a timing light.
Old Jan 8, 2009 | 07:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I just bought the Harbor Freight unit. Have not used it yet but the price was around $20.
Old Jan 8, 2009 | 08:02 PM
Car: 87 Trans Am
I think I paid about $20 for mine too. I used one of there die grinders also. Just don't have it set on the full setting when you have sanding/flapper wheel on it. I did that by accident things got interesting for a little while. I'm glad i was wearing my saftey glasses.
Old Jan 11, 2009 | 01:42 PM
Engine: All 5.7's
Thanks for the info and tips Guys! This is why I love this site, Someone always has the answers I need! I ordered the tools today. Thanks again!
deracer
Apr 11, 2016 12:04 AM
19irocz85
Aug 26, 2015 07:54 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
