View Poll Results: Which cam would reach 325-350hp with stock heads?
Crane Powermax 2032
25.00%
GM LT4 HotCam
25.00%
Comp Cam XFI 260
4.17%
Comp Cam XFI 268
41.67%
Other- state the cam and specs
4.17%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Crane 2032, CompXFI 268, LT4 hotcam? 350hp
Old Jan 5, 2009 | 12:46 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Crane 2032, CompXFI 268, LT4 hotcam- ?330jp
Which cam do you think I would be more likely to reach my goal of a 325-350 horsepower motor at the flywheel? My car is an 87 350 TPI with all free-mods, Edelbrock Headers, no emssions,heater valve delete, air delete, Walbro fuel pump, Hypertech Stage 2 chip, BBK afpr, Pro 700R4 built to 500hp, 2000rpm tc
My cam choice are the Crane 2032, CompXFI 268, or LT4 hotcam. I am in the near future going to go to a set of Patriot Freedom series heads but for now I'm running stock heads. I understand you can use offset valve locks and shims to get more lift out of the stock heads. I also plan on later updating to a TPIS intake with Edelbrock Runners, both ported.
Old Jan 6, 2009 | 09:50 PM
Car: '87 Iroc-Z
Old Jan 7, 2009 | 12:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Crane 2032 CompXFI 268 LT4 hotcam?350hp
Only the Comp 2032 will work with the stock heads, but the Comp XFI268HR-113 will give you the most horsepower, in my opinion. Its the newest cam with the best ramps.
Old Jan 7, 2009 | 02:20 PM
Car: '87 Iroc-Z
the comp cams wont work if I swap out the springs?
Old Jan 7, 2009 | 08:37 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: Crane 2032, CompXFI 268, LT4 hotcam- ?330jp
post the cam specs
Old Jan 7, 2009 | 08:54 PM
Car: '87 Iroc-Z
okay
Crane:RPM Range: 1,800 to 5,800
Duration @ .050" lift: 214/220 (int/exh)
Valve lift: .452"/.465" (int/exh)
on a 112 degree lsa
GM LT4 Hotcam:Hot Camshaft (P/N 24502586 Specifications
Intake Exhaust
Lobe Lift 0.328” 0.328”
Valve Lift
@ 1.5 ratio 0.492 0.492
@ 1.6 ratio 0.525 0.525
Duration
@0.006 cam lift 272° 281°
@0.050 cam lift 210° 228°
Lobe Centerline 109° 115°
Lobe Separation 112°
Comp XFI268:Lift: .570"/.565" w/1.6 Rockers
Duration: 268°/276°
RPM Range: 1800-5800 on a 113 lsa
Old Jan 8, 2009 | 11:53 AM
Kevin91Z's Avatar
Swapping the springs will get you at most .525" lift, and that's pushing it. And I wouldnt recommend anything bigger than the 2032 for stock heads. For all the hassle of a cam swap, save it and do the heads, cam and intake manifold at the same time.
Old Jan 21, 2009 | 09:48 PM
Car: '87 Iroc-Z
bump
I need some more responses~
Old Jan 22, 2009 | 12:38 AM
Chevhead89's Avatar
Re: Crane 2032, CompXFI 268, LT4 hotcam? 350hp
what he said save it for all at the same time because the cam you want isnt gonna work with those stock heads.
Old Feb 3, 2009 | 10:48 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Sorry I did not respond to your PM at a sooner date.
I love my 2032 cam. It sounds great and it was a pretty big improvement for my little 305.
I wish I would have had $$ for some heads as stated above. But how much money to you stick into a 305 with 100,000 miles on it.
Everything I bought I can swap over to a 350 build with no problems.
I bought a ported and polished plenum, Edelbrock hi flow runners and the edelbrock ho flow intake.
New springs are a must if your swapping out the cam with a larger lift.
You roller rockers should be fine. I did not buy new ones for my car.
I did buy a holley adjustable fuel pressure regulator, 24# LT1 injectors, new double timing chain and gear sets.
You can take everything off. Buy yourself a tool that threads into the spark plug holes to you can hook up an air compresser. When your changing the springs, this will keep the valves from falling down.
****this is a very good time to change those valve seals!!!****
I had to get my car tuned for it to run good enough to drive.
But my 305 is a nice little runner for what it is.
My 350 build is already in the works with a block bored .040 over already.
I have a steel crank lined up. Heads will be the biggest thing to find.
Best of luck.
But I do like my cam!
Old Mar 30, 2010 | 08:48 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Hey man, I want to ask what exactly you experienced with this cam? Did you have any drivability problems? Did you still use your stock computer chip? What kind of gain did you see with this cam. I have a 91 350 tpi and i am looking for a cam that i can run with a stock engine and ecm. Basically i just want more power without doing a spring change,etc.
Old Mar 30, 2010 | 08:59 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
I had to get mine tuned, It would not stay running and was dumping gas like crazy!
But it could have been because 5 out of the 8 fuel injectors were bad.
I love the cam, it sounds awesome, no drive-ability problems at all. I picked up more top end with the cam, stronger mid range as well.
Where the stock cam would die at 4500, this can goes till 5500 with no problems. I know my stock heads are a bottle neck, probably would flow a lot better with different heads, but its a fun car. I don't race it anyway.
Old Mar 30, 2010 | 11:34 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I just put together my ZZZ 350, swapped out the 235/235 cam and 113 heads for AFR180's and a XFI268 with ported accel runners base and plenum. When I get it on the road I'll post some opinions and info. I think what everyone else has said here is the same thing you will continue to hear. Heads are holding you back. NO cam will ever give you it's true potential without some decent heads. With that being said, a cam doesnt always have to be a "bigger" cam to give you load of power. A well matched combo is the key. I hope to be surprised when I get to dyno the car. Good luck with your build
Old Mar 30, 2010 | 11:53 PM
Car: '87 Iroc-Z
Wow can't believe it's still going! This thread is over a year old...I've sold that camaro got another iroc and have a 383 stroker that i'm needing to put it.
Hotrodboba400
Dec 10, 2019 07:07 PM
thekurlyone
Sep 30, 2015 12:54 PM
alpine247
Sep 16, 2015 05:25 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
