New fuel injectors. PROM upgrade?
Old Jan 16, 2009 | 10:18 AM
CCrockett86's Avatar
Car: 1987 Camaro Z28
I got new .26lb injectors for my car to replace the stock ones.
Will the car run at all, okay, good, or better with the new fuel injectors if I do not do anything to the stock PROM?
Old Jan 16, 2009 | 10:24 AM
Russ-So Cal's Avatar
Re: New fuel injectors. PROM upgrade?
You will probably run rich. The stock prom thinks you have 22 lb/hr injectors in the engine.
Old Jan 16, 2009 | 10:30 AM
What, apart from DIY PROM programming, can I do to help this?
Chip editing/burning is far beyond my skill and know-how.
Old Jan 16, 2009 | 10:40 AM
If you get an adjustable fuel pressure regulator, you can experiment with lowering the fuel pressure. The amount of fuel injected is a function of the amount of time the ecm holds the injectors open (injector pulse width) multiplied by the amount of pressure on the fuel rail. Your ecm is going to provide the injector pulse width for a 22 lb/hour injectors, so you need to drop the pressure so that it doesn't flow as much fuel. Your best bet is to do it at a chassis dyno so that you can get a measure of the mixture in the exhaust system.
Old Jan 16, 2009 | 09:25 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Do you have a scanner so you can see what's
happining when you lower the fuel pressure
You don't want to get it to low.
Old Jan 17, 2009 | 12:34 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nothing, really. Adjusting the fuel pressure is a band-aid, and you're creating a new problem when you fix the original problem.
A custom computer chip is the best, and only, fix. Post in your regional board and see if there is someone local who can help you.
Old Jan 17, 2009 | 03:18 PM
Thanks, that was a huge help. I'll see what I can get done.
Old Jan 20, 2009 | 11:29 AM
So, I'm on the hunt for 22 lb injectors and cannot find anyone who sells them in sets of 8--I've found individual ones for 100+ per (very out of my budget). I've found plenty of 19 lb & 24+ lb sets, but no 22 lb sets. Any suggestions?
Also, do you guys know if the injectors used on the '87 Camaro are the Bosch III design?
Old Jan 20, 2009 | 09:22 PM
Kevin91Z's Avatar
Both Summit and Jegs sell 21lbs/hr injectors. They're the same thing as 22lbs in our cars.
Old Jan 21, 2009 | 09:15 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
go to www.fuelinjectorconnection.com, Jon will help you. You can get a set of 22lb injectors from $134-$169
Old Jan 21, 2009 | 11:10 AM
David 91RS/Z28's Avatar
I think Accel offers them....although I haven't heard the greatest feedback on them. Keep looking for the 22's or something close to it as possible. If you need something quick and cheap, look for the Mustang guys selling their stock 19lb'ers. Ford injectors are rated on different fuel pressure so that would get you pretty close. Otherwise be prepared to buy a custom chip.
Old Jan 28, 2009 | 09:31 AM
I went to Jegs.com to try and find the 21lb injectors and I did find them. In the item description they give a link to a chart that says the stock 1987 Camaro 5.7L injectors are 24lbs. I really have no idea what I want to throw in there at this point.
Also, should I get the high-flow or high impedence injectors (the engine is fully stock)?
Here's the link to the chart that says the stock injector size part #:
http://www.jegs.com/footnotes/accel_fuel_injectors.html
Old Jan 28, 2009 | 01:01 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
As another poster had stated, go to FIC and get a set of the 22lbs bosch design 3. I got a set for my car and am very pleased. They only cost $169 for all 8 and come with a 3 year warranty. John modifies their bases so they have the correct installation height for our cars. Call him, you will find him to be very helpfull and all your problems will be solved.
Glowsock
Jul 24, 2025 03:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Firechicken86
Aug 12, 2015 10:07 PM
djmarch
Aug 10, 2015 08:42 AM
