Computer question
Old Jan 21, 2009 | 01:06 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
Computer question
I have a 85 camaro, it came stock with a 305 TPI but swapped it to a 350TPI. The PO swapped the motors but I had it rebuilt about 1200miles ago. Now I took it to get emissions and it runs really rich(limit is 1.8 car read 3.4) now is there a possibility I need to do something with the computer? can the stock one run a 350? if so how can I check to see if it hasnt been done already. and even though it was disconnected from the car during the rebuild did I still need to get it wiped or just tuned?
thanks in advance
Old Jan 21, 2009 | 04:26 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Computer question
305's came stock with 19lb injectors.
350's came stock with 22lb injectors.
The ECM can feasibly accomodate a 10% differential in injector size without programming. Your best bet would be to put in 22lb injectors.
Another option is to put in 19lb injectors but it will run lean in the higher rpm's.
Old Jan 21, 2009 | 07:11 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
try replacing the o2 sensor to begin with
Old Jan 21, 2009 | 09:21 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
How do I know if they are 19 or 22lb injectors?
I am going to change that I just havent gotten to it yet. I dont ahve a check engine light cause there is no bulb in there(PO) I want to just get it scanned
Old Jan 21, 2009 | 10:25 PM
jamon8's Avatar
Engine: 350 tpi
yeah eventually you need to have some way of getting a reading from your computer
if you have a laptop you could use a program like winaldl
or buy a scanner tool
or spend like an hour or two and I wopping 1 dollar for a bulb and get on with it
on the other hand if you have a ton of cash laying around and a needy mechanic
carry on
Old Jan 21, 2009 | 11:28 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
carry on
whats this program you speak of? I have a labtop(brother does really its a Apple)
what good is putting a bulb in there going to do? is there a stomp test I can do?
Old Jan 22, 2009 | 02:52 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
THe program needs windows. its basically a scanner program for your laptop computer instead of spending hundreds of dollars on a stand alone scanner.
Putting the bulb in for SES light would make it to where you dont need a scanner or anything fancy to get the codes. All you would need is a 2 cent paper clip, 5 minutes of your time, working SES light, and the chiltons manual or internet to look up the codes.
Google is your friend btw
Old Jan 22, 2009 | 10:03 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
hmmm well I dont have a windows I have an old one that bearly works lol.
now what is the paper clip going to do? lol. please feel free to enlighten me, I am perfectly willing to put the bulb in. just need to know where to go from there :-P I used to own a BMW and you could stomp the gas and it would blink out codes on the SES
Old Jan 23, 2009 | 11:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
You use it to ground out ports A and B on the aldl connector. It causes the SES light to blink the codes.
Old Jan 23, 2009 | 12:16 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
ahh there we go so the aldl connector is the one under that dash right? (sorry if I sound stupid lol)
Old Jan 23, 2009 | 01:58 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yep. Under the dash on the drivers side.
Old Jan 23, 2009 | 02:59 PM
Russ-So Cal's Avatar
When the engine was swapped was the ecm changed? The 1985 ecm is the first tpi ecm and is the slowest. Also 1985 Third Gens were only available with the 305 not the 350. As was mentioned previously, 350's run 22lb injectors, 305's run 19 lb. If you have the stock ecm and it thinks you have 19lb injectors on a 305, you may run lean. If you have an ecm that thinks you have a 350 with 22 lb injectors, it should be about right. If the 350 was swapped in with the 22 lb injectors, but the ecm thinks it is still a 305 with 19 lb injectors, it will may run rich. The ecm cannot tell what size engine you have or what size injectors you have unless you have the chip cleaned and reburned with the correct information. Another possibility is that the ecm has been set up for the correct engine/injector combination and you have one or more leaking injectors causing the lean condition.
Old Jan 24, 2009 | 07:33 AM
jamon8's Avatar
Engine: 350 tpi
its quite possible you should stick to a carb
or you could pick up some books and learn multi-port fuel injection
Old Jan 24, 2009 | 09:36 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
right, well ill hop to it this weekend I need to put a switch on my electric fan, it only works when it wants too
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
