comp 268h-10 to big for modded 305?
Old Feb 5, 2009 | 07:26 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I have a new 268 with 224/230....477/480...110. I have a 1987 TA with TPI 305 with a MAF when the cam goes in this will be the setup..... K&N,ported tpi upper and lower,slp runners, flow matched 19lb injectors from Cruzin performance straight from the shop 0 miles, ported and polished rebuilt 601 heads with 53cc chambers,1.6 RR,airfoil, headman headers, msd 6al and coil, 2200 stall converter in a slightly modded 700r4 with 2k miles on it,aluminum drive shaft and a 3.42 pbr disc rearend. I know the 110 is going to affect vaccum but is it to much cam for the smaller sbc?
Old Feb 5, 2009 | 07:31 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: comp 268h-10 to big for modded 305?
You will have a lot of tuning to do with the 110* LSA. You may want to consider the comp 264hr12.
Old Feb 5, 2009 | 07:46 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The question is how good a tuner are you?
I think you should get a real handle on the tuning before swapping cams.
Old Feb 5, 2009 | 08:02 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I can tune a radio .... I was going to send the 305 chip out to have it burned otherwise I think Im going to have to trade this cam.... its a flat tappet anyway...
Old Feb 5, 2009 | 08:33 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Why? You live in Chicago, home of some of the best tuners out there.
Do NOT try to get a mail order tune for a cam like that.
Old Feb 5, 2009 | 08:38 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
OK. It shouldnt be to bad considering my stock cam is 108lsa
Old Feb 6, 2009 | 09:23 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That's not correct.
LSA is relative.
You can only compare LSA when comparing similar duration numbers.
Your stock cam probably has at least 20* less duration.
Old Feb 6, 2009 | 10:08 AM
Saculia's Avatar
Engine: 305TPI
You are not going to be happy at all with a mail order tune. You need to have that car tuned under real driving conditions using a wide band O2 sensor.
Old Feb 6, 2009 | 10:44 AM
David 91RS/Z28's Avatar
Interesting... The cam sounds a little healthy on duration for a 305, but I'm really interested to see how it works if you do decide on it. The 110 will take more tuning in the puter, so see if you can find someone that can tune the car first hand. Otherwise you will just go back and forth with a mailorder tune. I would advise on bumping up the stall to somewhere around a 2600 minimum for best results. 3.73 gear as well. Good luck and keep us posted on the setup.
Old Feb 6, 2009 | 09:50 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im not looking to make a drag car out of this,,,I want to get into autocross this summer... I have the chance to buy back a xe258hr http://store.summitracing.com/partde...8&autoview=sku should I just go that route since I can get it for $100 thanks
Old Feb 7, 2009 | 12:44 AM
Saculia's Avatar
Engine: 305TPI
I have the same cam in my LB9. I love how it runs. It will need a tune to get it to run right, but you will be able to drive it on the stock tune. Compared to your stock small cam, this will seem like a beast.
Old Feb 7, 2009 | 09:01 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
The 268 or 258? which one is in your car? thanks
Old Feb 7, 2009 | 12:34 PM
Saculia's Avatar
Engine: 305TPI
The 258, comp cam 08-500-8, grind # xr258hr12.
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mz92274
Aug 25, 2015 08:47 AM
st.evel07
Aug 13, 2015 06:15 PM
