tbi to tpi
Old Feb 20, 2009 | 09:42 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
tbi to tpi
i have a lO5 v8 tbi, i am wondering what i would need to get to make it a tpi. i have an 89 camaro rs that used to be a 305 tpi and it still has the wiring harness and i know that i would need to get the tpi set up and an ecu but would i need to get different head and whatelse would i need to get? thanks
Old Feb 20, 2009 | 10:27 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: tbi to tpi
If you have the TPI harness, all you will need is the TPI and the chip. I did some research and found the TPI and TBI computers can be used on each other. No need to get different heads or anything else. You will need all the sensors and relays. Also, if you still have the 89 RS, you might need to change the fuel lines, but what you have already should work. Good luck with it.
Old Feb 21, 2009 | 10:40 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Re: tbi to tpi
thanks for that but im just bout to get ride of my car everything keeps breaking everytime that i start thinking about doing anything cause i saved up for a month and then put a few things up then the water pump gasket goes out, yea its not much but there has been so many things break im about to get rid of it.
Old Feb 21, 2009 | 11:38 PM
RobSS1113's Avatar
Re: tbi to tpi
I did a swap from TBI to TPI ... ask me to do it again and I will say "hell no" !!!!
same block , same heads etc... now its TPI . sorry did the swap like 12 yrs ago and I dont remember how
Old Feb 22, 2009 | 01:49 PM
chindo's Avatar
Car: 1976 Trans An
Re: tbi to tpi
was the swap that bad or did you not notice enough diffrence?? I to want to change my 92 rs TBI to TPI intake setup and looking for a harness as we speak, and the prom as well I believe the ECM are the same just that proms need to be changed right
Old Mar 3, 2009 | 05:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: tbi to tpi
Is it hard
Old Mar 3, 2009 | 11:49 PM
Texas92's Avatar
Re: tbi to tpi
You can use you tbi harness but you have to change the ecm they are diffrent
Old Mar 5, 2009 | 02:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: tbi to tpi
This is a very common topic, and its very worth it to do the swap.
There's also a tech article linked in the Tech Articles section in the main page of this website.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
