Mini Ram and emissions?
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
What if I knew a guy that knew a guy who's mother in law's sister's aunts cousin's best freind's uncle three times removed owned a smog shop and as long as the car passed the sniffer, he'd pass it. If that were the case, and someone put a Mini Ram on their TPI based motor, and installed the add-on EGR kit, would it pass the sniffer? Then would it be worth spending the grand on the setup to run fast?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Mini Ram and emissions?
Sure, you could possibly pass the sniff test without the EGR, but you'd need it to pass the visual. Spending the $1000 price tag is up to you.
So are you saying that the Mini Ram with the EGR kit would be a smog legal (CA too) part. Does it have an EO#? I didn't see one.
I think a lot of the question has to do with what ELSE you're going to do to the motor. THEN.....when all is said and done....."will it pass?"
*EDIT* Just saw your sig. 383. Heck, sure....yank off the TPI and go for it. I imagine they'd pass you, regardless of OE, assuming you added the EGR. ...but then you ARE in Cali. I know here in NC, which is MUCH more laidback, you'd have no trouble.
No, putting an EGR setup on a MiniRam does not give it an EO#. Those come from the state after submitting the product thru a series of tests. Last I heard those tests cost about $35,000.
Wasn't there a guy on this board who tried to run a mini-ram on a 1970-72 Camaro, and finally gave up because he couldn't get it to ballance the airflow between the front and rear cylinders?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
could try to pass it off as a LT1 and maybe they wont know? Either way, the EGR kit may pass with flying colors but still dont have a EO number
I dunno if its true or not, just what I heard from a guy who knows a guy.
Car: 1992 RS
