cam questions
Old Mar 12, 2009 | 11:47 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
cam questions
looking for a cam for my 305 TPI, the motor is an 88 so it shought have a hydraulic roller cam, i have searched around and seen the crane cam 2032 mentioned alot for a bone stock 305. with that cam, do i need to replace my lifters too? or can i keep them, and is there anything else i would need for the cam to work?
Old Mar 12, 2009 | 11:59 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: cam questions
Is this the first mod to your motor?
Old Mar 12, 2009 | 12:00 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: cam questions
Usually you can get away with reusing lifters on roller motors, its flat
tappet cams/lifters that can get you into trouble. I like to replace
whatever I can when upgrading internal parts. How many miles are
on the lifters?
How good condition are the heads?
Old Mar 12, 2009 | 12:10 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: cam questions
I still have my stock push rods and stock lifters, I have 100,000 miles on my 305.
I reused them, motor runs good. No problems at all.
I know Crane is out of business, but the cam I used is in my sig.
Old Mar 12, 2009 | 12:26 PM
Chevy8588's Avatar
Re: cam questions
it is my first mods which will all be done at one time. which will be a new cam, plus a new metal cam gear, an MSD dizzy and blaster coil, gunna also do hearders and y pipe, if budget allowing, a cat back. there is only about 10k on the motor, it was replaced a few years back. there is no valve tick or anything from the motor, runs strong and quiet.
Old Mar 12, 2009 | 12:35 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: cam questions
That's great to hear!
Yeah its hard to pull out a good running motor. My 305 runs great.
But I do have a 350 bored .040 waiting in its place
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
