ignition key stuck
Old Mar 31, 2009 | 01:53 PM
GTA BANDIT's Avatar
Car: 1991 Trans Am Gta
Engine: 350 Tpi
ignition key stuck
my ignigtion key is getting stuck in the cylinder. i cant turn it at all. i figured out what was goin on. my car is an automatic with the 700r4. the shift button that you push in to move this shifter is getting stuck inside of the handle. once i unstick it i can move the igniton key. what is causing this?
Old Mar 31, 2009 | 02:28 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: ignition key stuck
There's a cable operated interlock on the ignition switch mounted on the steering column under the dash that prevents the lock cylinder from moving when the gearshift is not in park or neutral
The button getting stuck is probably causing the problem.
Old Mar 31, 2009 | 02:31 PM
GTA BANDIT's Avatar
Engine: 350 Tpi
ok. how do i adjust this?
Old Mar 31, 2009 | 04:36 PM
You have to fix the button on the shifter, the cable is not adjustable.
Old Mar 31, 2009 | 05:47 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Pop the little clip out of the front of the shift **** with a paper clip. That will release the **** so that you can look in and see whats causing it to bind. You may also want to pull up the gear selector panel to check the shifter linkage, make sure nothing is binding up.
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
TexasMaro
Sep 15, 2015 06:50 PM
383cam
Sep 9, 2015 06:01 AM
