quick tpi question
Old Apr 4, 2009 | 10:09 PM
cmtison's Avatar
Car: 1992 B4C
Engine: L98 soon to be 383
quick tpi question
in the 89-92 camaros.. did the 305tpi and 350tpi have the same size intake manifold/plenum/runners/and TB?
Old Apr 4, 2009 | 10:34 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: quick tpi question
Yes, only the injectors were different.
Old Apr 4, 2009 | 10:56 PM
cmtison's Avatar
Car: 1992 B4C
so if i was to toss out the 305 engine and put in a 383 i could reuse the intake but i would probably need new injecters?
Old Apr 5, 2009 | 02:29 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
The tpi was designed for the 305 so it starts to become a restriction on the 350.For a 383 it would be a major restriction.That doesnt mean people dont do it.The 383 would be faster than the 305 and have more power but would benifit even more from an aftermarket tpi intake or other form of EFI or carb induction.Yes you would need bigger injectors.Try out the .It can be a major PITA sometimes but every question you could prolly come up with has most likely been answered.welcome aboard
Old Apr 5, 2009 | 07:13 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Using a standard TPI on a 383 is a terrible idea. You have several options, none of them cheap. You could switch to an Accel Super Ram intake, you could switch to a TPIS Mini Ram intake, you could switch to a Holley Stealth Ram intake, you could change the entire EFI to an aftermarket system like a Comander 950 from Holley, or you could have an LT1 intake modified to work on your engine (do a search there is a lot of info on this on this forum). Best case scenario you are goign to spend $500, worst case well over $1,000.
However, to build a killer engine like a 383 and then saddle it with a TPI intake would be just as foolish as continuing to run stock exhaust manifolds. Modifying these EFI cars is more expensive than a car with a carb, but the rewards are well worth it.
Old Apr 5, 2009 | 10:09 AM
cmtison's Avatar
Car: 1992 B4C
the intake manifold itself will be after market to start with comes with the engine. Yes i knew the stock tpi is restrictive but it is also something i can use till i put on a bigger intake. So my question is if the stock TB and runners off a 305 are the same size as the stock TB and runners off the 350?
Old Apr 5, 2009 | 11:47 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
yes.The lower manifold may need to be modified depending on what heads toy`re going to run.
Old Apr 5, 2009 | 01:19 PM
cmtison's Avatar
Car: 1992 B4C
im buying the engine completed with dart heads and an aluminum lower intake so i think that the plenum and runners would hook right up. correct me if im wrong but i believe vortec heads is the only head that requires special intakes.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
