Oxygen Sensor Replacement
Old Apr 7, 2009 | 08:00 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
How do you get the o2 sensor off, I can get a offset wrench on it , but it can't turn it enough to get the wrench back on. This car has the california emissions so thats stuff is kinda in the way too. Is there a special tool or something to use?? I was thinking if i had an offset open ended wrench instead of a box end it would probably work.
I even tried to get at it from under the car but there just isn't enough room
Old Apr 7, 2009 | 08:06 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Oxygen Sensor Replacement
think theres a socket for it. i know what you mean i have the smog stuff to but im getting rid of it soon.
Old Apr 7, 2009 | 08:40 PM
Car: 86 Z28
I don't think a socket would fit over the wire though there would be no where for it to go
Old Apr 7, 2009 | 08:43 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I got mine out with a 22 (I believe) wrench and IIRC It makes it much easier if the exhaust system is fairly warm when you try to remove it.
Old Apr 7, 2009 | 08:47 PM
Car: 86 Z28
i got it to turn but can't turn it far enough, I'll try a 22mm wrench if i have one
Old Apr 7, 2009 | 08:52 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
there is a socket made for it , it is split about 3/4 the way up one side give room enough for the wire to come out . i think you can go to autozone and rent one and they sell them too,jimmy
Old Apr 7, 2009 | 08:55 PM
Car: 86 Z28
thanks, I'll check that out tomorrow
Old Apr 7, 2009 | 09:03 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
part #27110 at autozone $25.00 ,jimmy
Old Apr 19, 2009 | 11:22 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i got it off with an open end wrench while the exhaust was alittle warm. i believe the size was like 7/8's or something like that
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
