Need help with fuel rail feed/return line part #'s
Old Apr 19, 2009 | 09:06 PM
Twinturbo502BB's Avatar
Hello everyone; I am working on a 91 z28 convertible 350 TPI that I am trying to get back up in running, I am replacing a broken hard metal fuel line(the ones that connect from where the fuel rail is secured to the block)
I'm sure I can make some new braided lines or find some at a junk yard, wanting to keep it stock though.
anyone have a part # for these two lines? I have a pic to show you what Im referring to
thanks for any and all info in advace
James G
Attached Thumbnails Need help with fuel rail feed/return line part #'s-fuel.jpg
Old Apr 20, 2009 | 10:09 PM
Re: Need help with fuel rail feed/return line part #'s
Anyone at all?? really having a hard time with this part #
thanks
James G
Old Apr 21, 2009 | 01:04 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You can ask the folks at gmpartsdirect.com, but I bet they are no longer available.
Old Apr 21, 2009 | 04:22 PM
thanks, Ill try that
Old Apr 21, 2009 | 10:20 PM
wow, really having a much more difficult time finding these parts than I thought.
Old Apr 24, 2009 | 09:47 PM
still having no luck with finding this part, any help would greatly be appreciated
thanks
James G
Old Apr 26, 2009 | 12:45 AM
anyone?????
Old Apr 26, 2009 | 08:56 PM
still searching,,,
Old Apr 27, 2009 | 03:23 PM
tried every vendor I can think of out there, junk yards nearby are scarce, anyone have any suggestions??
thanks again
Old Apr 27, 2009 | 10:16 PM
ok so Im thinking maybe it would be easier to just get some -an adapters and make my own lines to replace the bad lines Im in search for. However the car isn't near me right now, anyone have the thread sizes, suggested fittings etc to do what Im talking about, basically line from end of fuel rails to lines located on driver side firewall?????? refer to the pic.
Old Apr 29, 2009 | 05:28 AM
Pocket's Avatar
Car: 91 Trans Am
http://www.jegs.com/p/DFI/745157/10002/-1
I have a set of stock lines if you're interested
Andrew6.688
Dec 13, 2015 10:59 AM
wayshegoes
Aug 17, 2015 12:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
1nastygta
Aug 8, 2015 07:38 PM
92projectcamaro
Aug 6, 2015 01:20 PM
