poor driveability
Old May 2, 2009 | 05:52 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
poor driveability
Please someone, I need help. I have a 91 Z28 5.7L TPI Auto. The car is running terrible, I have posted issues before and recieved responses and suggestions but nothing seems to help. The car has very poor idle quality, and runs hot. I keep getting ESC module codes, lean codes. I have changed the O2 sensor, knock sensor, ECM, prom, IAC, TPS, coils, cap rotor, plugs, wires, reset ignition timing to specs, and injectors. The car doesn't have a cat, or air pump. It has headers with 3 inch exhaust. The car stalls alot, and if its over 70 degrees outside it runs well over 220+ degrees. All cooling system components have been changed except for the heater core. The dtc's don't stay in the ecm ( the check engine light comes on and goes off at random times). Today I was screwing around with it and I pulled the number 3 spark plug wire off and the idle quality got better( no misfire), but off idle it obviously misses, same thing happens if I remove the harness connector for cyl#3 injector. I really don't know where to start because it seems like it just keeps developing more problems. Has anyone experienced similar problems?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
shanelique22
Sep 24, 2015 06:30 PM
lakeffect2
Sep 7, 2015 03:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
