305 TPI Cold Start Injector Replacement HELP! PLEASE!
Old May 13, 2009 | 12:21 PM
camarox1971's Avatar
Car: 1985 Chevy Camaro Z/28
I need to replace the cold start injector on my 305 tpi and dont know how. It seems like an easy task but I want to make sure if I screw up it wont ruin my engine. Its an 88 tpi 305. If any one has step by step instructions it would be greatly appreciated. I want to get this Camaro back on the road soon.
Old May 13, 2009 | 12:31 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Re: 305 TPI Cold Start Injector Replacement HELP! PLEASE!
are you sure an 88 has the cold start injector? What are your symptoms? no start?
Old May 13, 2009 | 12:33 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
REAL EASY..remove the line from the fuel rail.. take out the 1 bolt that holds the injector in the manifold. Once you get it out you will see a tab that keeps it from spinning.. bend that tab upward out of the way.. hold the line with 1 hand and unsrew the injector to the left untill you can pull it free from the line. Thats it.. To answer the post above.. 85-88 have cold start valves
Old May 13, 2009 | 12:55 PM
yes im sure.
Old May 13, 2009 | 12:57 PM
^ To the person with instructions. This is all i have to do? If i open the hood and start working on it for the first time this is all I need to do?
Old May 13, 2009 | 01:31 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
That's all you need to do!!!!
Old May 13, 2009 | 01:36 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
A couple of other things to look for. The line from the cold start goes to the back of the fuel rail, and sometimes can begin to leak. If you are going to take it apart, get the O-ring kit to replace both orings- the one on the cold start and the one at the back of the rail. Also, do you have the new valve? I tried to buy one a while back, and could not find one anywhere. Wound up eliminating the cold start via a change to '89 code in the ECM and a cold start delete kit from EBAY. Last, is the cold start valve bad? Have you checked the cold start switch at the front of the manifold? And all the connectors? Jon at FIC can clean and test your Cold Start Valve. He tried to fix mine, but it was not repairable.
Old May 13, 2009 | 01:43 PM
J91's Avatar
J91
I have one on my old TPI setup if you need. less than 20K on it. It worked fine up until last August when I pulled the motor....
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 6, 2015 04:20 PM
