egr holes in plenum
Old May 27, 2009 | 08:05 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
egr holes in plenum
i just recently ported my plenum and runners a bit on my 87 tpi and when i put it back together i have a slow responding idel.Iv checked everything and all i can figure is that where the egr holes are its blowing air in insted of sucking it out and the ecm is trying to compensate and when it cant get it right it finnaly gives up and just does it by rpms insted causing the slow response time in cutting the idel down to 600.Thats my last resort cause everything elts checks out(havent changed ecm yet) so my qustion is i should be able to cut the back side of the holes a little lower than the front so when air passes it pulls it out insted of blowing it in.Do you guys think my theory is right or am i just all wrong lol.The problem just started when i done the porting so it has to have something to do with that. Im lost so i need all the help i can get thanks.......
Old May 27, 2009 | 08:32 AM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
Re: egr holes in plenum
sounds like u got a vacuum leak and its messin with the ecu because it has no way to read the incoming air thats not going through the MAF i would check there first make sure u put all vac lines back on?
Old May 27, 2009 | 09:12 AM
Damon's Avatar
At idle the EGR system shouldn't be functioning at all. There should not be anything going in or out of the holes in the plenum floor.
Old May 27, 2009 | 09:37 AM
Car: 87 iroc z
Engine: 358 tpi
There are no vac leaks like I said I have check everything and i mean everything 3 times lol the holes are my last option and changing the ecm.See im thinking that maybe I have the front of the holes a little lower than the back causing air to be forced down in the holes insted of sucking it out which is what the ramps are there for in the first place by the way they look.I might be wrong but thats what it looks like to me.And Im guessing that they might be messing with the ecm causing the delay of ideling down.I never had this kind of problem at all till I did this and everything elts checks out so I hope fixing it so the air will suck on the hols insted of blowing in them will fix the problem if not all i can do is change the ecm then put a stock plenum back on which i dont want to do at all.Keep the ideas comeing everything helps I might have over looked something simple I checked everything but you never know...........
91chevyz28
Feb 10, 2022 07:58 PM
gta892000
Aug 11, 2019 11:16 AM
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
italiano67
Sep 22, 2015 08:42 AM
