odd problem
Old May 30, 2009 | 02:14 PM
Trinamo's Avatar
odd problem
trying to get the bird running right because it was missing and smoking and so on, I've changed out the Fuel pump, fuel filter, air filter, fuel regulator, MAF, cap, rotor, plugs, wires. Its running better but is still missing/ running rough and pluming a light colored smoke when given gas, in addition to that, the rear driver side runner from the plenum to the manifold is crazy cold when the car is running. So cold it condensates like a soda out of the cooler
Old May 30, 2009 | 02:27 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: odd problem
Injectors? Worn engine?
As for the cold runner, I don't think many here will think of that as much of a problem. I say try and figure it out then make the rest of them match. Be sure to tell us what's causing it. ;-)
Old May 30, 2009 | 04:40 PM
Trinamo's Avatar
Re: odd problem
I wouldn't mind it being cold if it were supposed to be, but its so cold its like grabbing the AC lines (no AC in my car so its not a suspect). I'm sure that it can't be good and that is why im wanting to get it figured out.
Old May 31, 2009 | 10:13 PM
Trinamo's Avatar
Re: odd problem
bump for help!
Old Jun 1, 2009 | 12:28 PM
Trinamo's Avatar
Re: odd problem
replaced IAC, nowhere near as much smoke but it does not want to do much, idles like crap, the runner is no longer freezing cold but it wants to die if i give it ANY gas
Old Jun 1, 2009 | 12:46 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: odd problem
check codes
make sure your Dizzy isnt 180degrees off
Check timing x2
Old Jun 2, 2009 | 04:43 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: odd problem
check your voltage on your TPS, should be .54v. what color smoke?
Old Jun 12, 2009 | 12:11 PM
Trinamo's Avatar
Re: odd problem
IAC, TPS, new and adjusted. Timing adjusted. Plenum still cold, going to replace injectors. New symptom, plenum is full of gasoline, as in i took it off and it poured all over the top of the engine
Old Jun 12, 2009 | 12:19 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: odd problem
Well, there you go. Most like coming thru the vacuum host to the pressure regulator. That would explain the cold runner.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
