How to remove the plenum
Old Jun 11, 2009 | 02:39 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
can someone give me detailed instructions on how to remove the plenum im trying to get to my egr valve to replace it i cant find anywhere someone explains how to do this
thanks in advance
Old Jun 11, 2009 | 02:56 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
Re: How to remove the plenum
easy! first disconnect the battery (neg first) then unplug any wires from the throttle body, maf ect. then take the air intake and throttle body off. undo the plenum to runner bolts and losen the runner to intake manifold bolts on the drivers side, this makes it a bit easier. , using the wooden handle of a hammer, gently tap the rear of the plenum at the rear downwards.thers a vacum hose from the servo at the rear of the plennum and a air intake temp sensor, unhook those and hey prsto!
Old Jun 11, 2009 | 04:42 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
i pretty much did that but i couldnt get it to come loose
Old Jun 12, 2009 | 02:03 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Loosen to runner bolts, this will also make it much easier when putting it back together.
Old Jun 12, 2009 | 02:33 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
thanks in advance
Loosen all the runner bolts there are 2 or three that are pretty hard to get at. need an extension and a star/torx tool. preferably one that connects to a socket. Loosen the bolts that connect to the intake manifold as well, not just the ones on top that you can see. Very good idea to get a gasket set to replace the ones between the runner tubes and the plenum. Tap it with a wooden or rubber mallet to break it loose. Be care ful there is a plastic vacume tee under there too. dont break it. well there was one under mine at least. let me see if i can find a link to show detailed instructions. when i did mine i was a little paranoid trying to be very careful not to damage anything. but once i did it it was pretty simple.
Old Jun 12, 2009 | 02:40 AM
Car: 1986 Iroc z
Engine: 350 tpi
WOW i did a search myself and i actually started a thread a while back on this. so heres the link alot of guys helped me out here. good luck;
https://www.thirdgen.org/forums/tpi/...oval-help.html
Old Jun 12, 2009 | 04:44 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
thanks for all the help everyone
Old Nov 4, 2010 | 06:59 PM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
I can vouch for the use of the rubber mallet. My plenum was stuck. The gasket was holding it. Without the mallet hits (front and back), I would never have gotten the thing off!
Old Nov 4, 2010 | 09:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Doesn't always work ;
I have had to put a length of pipe through the TB holes in the plenum to get one off
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
