350 tpi problems
Old Jun 18, 2009 | 05:16 PM
19transam89's Avatar
Car: 89 gta
Engine: 350 tpi
350 tpi problems
well i decided to cut my plenum to match up with my slp runners, and now when i start the car it idles at @ 2000-3000. i have no clue, i have checked all connectors, wires and vacuum line and nothing seams to be wrong with them.
need help
Old Jun 19, 2009 | 12:50 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: 350 tpi problems
I had a large vacuum leak at the plenum/SLP runner surfaces and my engine would idle at 2200rpm. (In my case, the runners were on the wrong sides.)
Old Jun 20, 2009 | 02:04 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You probably messed up the gasket on reinstallation. I've done that before, and have also put the runners on the wrong side, as said above.
Old Jun 20, 2009 | 08:55 AM
Car: 89 gta
Engine: 350 tpi
thanks for all the suggestion, and the gasket was messed up. i really didnt think that a small chunk (maybe 1/4 in) would really make it idle that high.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
