INJECTORS CONNECTED WRONG?
Old Jun 19, 2009 | 06:14 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Hey Guys,
I just got my IROC running last week, but I had a runner intake leak which I had to fix. I did get the engine broke in before I fixed the intake leak. I fired it up today, and I noticed that number 7 header is glowing red hot. And number 5 header is faintly glowing. Could I have connected the injectors wrong like crossed them since they are not labeled.
Old Jun 19, 2009 | 06:41 PM
Guest
Guest
Posts: n/a
Re: INJECTORS CONNECTED WRONG?
Nope, doesnt matter where you hook them up.
Checked those spark plug wires, see if they are crossed?
Old Jun 19, 2009 | 07:45 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Its unlikely. The TPI system uses batch fire for the cylinders. Which means that all 4 injectors on a single bank fire at the same time.
Unburnt fuel could be causing it as well if its burning in the primaries. As mad max said check the spark plug wires, and plugs themselves.
Old Jun 19, 2009 | 11:07 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I say something is wrong with your timing possibly
Old Jun 20, 2009 | 02:32 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Also check for exhaust leaks especially near those cylinders, or the left side (driver) Y-pipe flange.
Old Jun 20, 2009 | 08:16 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Old Jun 20, 2009 | 09:23 AM
Car: 1988 IROC-Z28
Great thanks for the info!
I'll do all that, plus a parts store by my house is selling Accel Header plugs. They are shorter for more clearence, so I thought I'd pick those up and try them.
Old Jun 20, 2009 | 09:39 AM
Car: 1988 IROC-Z28
Oh as for my base timing, its at 16º and my cam is a Comp. cam with the following stats: model no#08-306-8 , duration at .05 230/244 , 1.6:1 lift .544/.576 , lob sep. 112deg.
Old Jun 20, 2009 | 01:39 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
your timing should be @ 6 BTDC with ESC wire disconnected (tan / black stripe) located at the passenger side near the AC blower
Old Jun 20, 2009 | 01:59 PM
Car: 1988 IROC-Z28
Ok?
how can that be if stock small blocks are set at 10 degrees advance, I don't think my engine would even run with the high lift it has in the cam. Just to confirm my setting I'm using the timing tab of the block at 16 degrees to the crank balancer at the zero mark. I'm Using a adjustable timing light. I'm lining up the crank balancer zero mark to the 16 degree engine timing tab. This is of course is with disconnecting the distributor/set timing brown wire.
Old Jun 20, 2009 | 03:30 PM
Guest
Guest
Posts: n/a
Way too much initial advance. Set it at 6 or 8.
Old Jun 20, 2009 | 03:42 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
I have mine at 6d's in my 406
Old Jun 20, 2009 | 03:45 PM
Car: 1988 IROC-Z28
Ok!
as a example should I set the base timing using the crank damper zero mark and set it to the timing tab at 6 0r 8 advance ?
Old Jun 20, 2009 | 03:53 PM
Guest
Guest
Posts: n/a
Yes. Or since you have an adjustable timing light, you can put that at 6 and have the mark at zero on the tab.
Old Jun 20, 2009 | 04:02 PM
Car: 1988 IROC-Z28
Thanks!!
I'm guessing that should also solve my glowing headers problem.
Old Jun 20, 2009 | 04:17 PM
Guest
Guest
Posts: n/a
It may. The computer is going to advance the timing around 15-20 degrees at idle so with a 16 base it was way too high. Might fix it, you'll know soon enough.
Old Jun 20, 2009 | 04:54 PM
Car: 1988 IROC-Z28
Well dropped the base timing down to 6 degrees, as the engine was warming up the headers again began to glow 5 and 7 with 7 being the worst. I also went with Autolite plugs # 3923 and gapped them at 45 thousands.
Old Jun 20, 2009 | 05:49 PM
Car: 1988 IROC-Z28
I noticed when its running you can hear a ticking sound on the drivers side. So I pulled the valve cover off, and found number 7 intake is loose, but 7 exhaust is not when I set the engine at number #1 TDC.
Old Jun 20, 2009 | 07:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Did the ticking stop when you ajusted #7
Old Jun 20, 2009 | 08:37 PM
Car: 1988 IROC-Z28
Yes the ticking stopped, and the header number 7 only faintly glows at base timing 6 degrees. Once I reconnected the ecm and it started to learn, that to seems to have gone away. I'm assuming at 6 degrees it was too retarded and was heating up. Then once the ecm kicked in it advanced the timing and the glowing header seemed to have stopped.
Old Jun 20, 2009 | 09:36 PM
Car: 1988 IROC-Z28
Just an update, my last post seems correct! So I'm back to dialing in.
Thanks everyone for your input!!!
Old Jun 21, 2009 | 10:07 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Ecm does not learn spark.
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
86Base
Aug 13, 2015 05:06 PM
Bull86
Aug 10, 2015 05:43 PM
