just completed a TBI to TPI swap but having problems
Car: 1988 Camaro sports coupe
I get fuel to prime, the engine cranks, but I have no spark. I also haven't tested to see if the injectors are firing or not... if anyone can help me out I would really appreciate it... thanx guys
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: just completed a TBI to TPI swap but having problems
you are still using the same distributor as before correct? If its a different distributor check in to the ignition control module or pickup coil. If it's the same 1 then you need to diagnose if its the injector driver or the wiring to the injectors.
well I took everything from the donor car... and I used the distributor from the donor car since that engne is a 5.7 TPI and the one I took out from my car was a 5.0 TBI
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
well someone will correct me if i'm wrong, at least i hope ,but i beleive the distributors on all late model efi applications 80-90s is the same on v8s pretty much. In other words use your old distributor and try again.
or if you would rather, pull your ignition control module and take it to the nearest autozone they can test it for you and that would most likely solve the problem.
if you still have a problem after rent noid lights from autozone and see if the injectors are pulsing ok.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
most likely the easiest thing to do is take the module off and have it test most likely therein lies your problem
ok I'm going to try those things thanx a lot hopefully this solves my problems
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
